Zanussi Jetsystem 1000 FJ 1040 I have had this machine a very long time, some 15/16 years, It has been the best thing I have ever purchased, but now we have a problem, the first I might add in its life. It will wash and do all the programs no problem, the proble is on spin and short spin, it will work intermitantly and now may well have stopped. Can anyone shed any light on how to resolve this problem Thanks
  • 1 more comment
  • hall_d8 Oct 01, 2009
    Thanks for that speed reply
    Can you tell me were the motor is and the best way to remove it, I would also like if you could to say were to get the brushes from, fitting them into the motor is not a problem.
    Thanks again for your help
  • hall_d8 Oct 02, 2009
    Had a good look at the motor, removed the brushes and they both have plenty of meat left on them. The motor and the belt look fine and the motor does run, the washer does operate, it just has a problem with the spin part of the program.
    Both the short spin and long spin it just won't operate.
    Hope this helps with another idea of how to fix the unit.
    Thanks for your reply
    It drains and pumps water out of the drum.
    The filter is clean and there are no blockages as I can see.
    Is there anything else that it could be?
    The programs that are the spin (old dial system) will not turn, is there something I can look at to see why this is, all the other programs works fine, just the spin and fast spin.
    Thanks for your help in advance.
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Motor brushes worn, Fit new brush kit.
Posted on Oct 01, 2009
  • 1 more comment
  • Gerry Harvey
    Gerry Harvey Oct 01, 2009
    The motor is located at the bottom of the drum , it is secured by arond 3 bolts removay is straightforward make sure this motor has brushes you will see them , check on website if your not sure how the look.....2screws hold each brush cost is about 15 G.B. pounds..hope you get on okay, Oh. if its no brush motor scrap machine....
  • Gerry Harvey
    Gerry Harvey Oct 02, 2009
    Could well just be the pump not pumping water .you could try cleaning filter .....
  • Gerry Harvey
    Spin knob is still available via u/k stocks ..some of the teeth snap and makes hard to select spin,,Good luck
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
Oct 09, 2009 | Zanussi FJS1225W Front Load Washer
How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
May 19, 2009 | Zanussi Washing Machines
Drain pump FJ 1454W
Prob sorted, phoned Zanussi service enginneer
Nov 13, 2008 | Zanussi FJ1454W Front Load Washer
Where can I order a new belt for my Zanussi IZ12 wasmachine?
bit of a nuisance doing it from afar but i have used currys masterpart ( a uk site) for ordering spares now i'm retired
Nov 12, 2008 | Zanussi IZ12 Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Zanussi Jetsystem
scrub above the soap tray to make sure the holes are clear if they are you may have a system where the fab condit water valve is u/s.
May 18, 2007 | Zanussi IZ161S Front Load Washer
Jetsystem not working
It sound like an clogged inlet water line issue. Check for clean filters and inleat water valve.
Jun 29, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
