Question about Video Cameras
Wen i turn my camcorder on,the whole screen becomes dark and i can see the objects only faintly
  • 125 Answers
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty. Good luck
Posted on Oct 01, 2009
Very dim display..so dark that all I see is a faint picture. Are bad capacitors to blame?
I would say either the video cable has disconneted, causeing the led that lights the screen up to not function,, simpley take the bezel around the screen, take the small screws aroud the screen to slightley pull the screen away from the back top to see if the cable is, or has pulled loose...If now the screen is bad..
Oct 13, 2014 | Samsung SyncMaster 930B 19" LCD Flat Panel...
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I'm doing mine myself. Results to follow, maybe, if I remember to post following the repair.
Jul 15, 2011 | Sony HDR-SR12 HDD Camcorder
Screen will not lite up
It may be that the backlight for the screen is out...you should take the booted machine into a dark room and see if you can see a faint light in the screen. If so, you need to replace the backlight. If you are fairly handy you can try and disassemble it and replace it yourself...otherwise replace the whole screen.
Jun 21, 2011 | HP Pavilion dv9000z Notebook
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Jan 06, 2011 | Computers & Internet
Dark LCD screen. Very faint image.
Internally it has a inverter board which go bad sometimes or due to heat sometimes get unpluged.So you will have to open it make sure when you do there is no power going to it.Look at the wires make sure they are snug and try again.
good Luck
Oct 04, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
When recording indoors light does not turn on picture very dark
wen u recordin indoor either switch on ur lights in ur room or in setting record mode put it in indoor so u can take clear and nice video ...
Sep 10, 2009 | DXG Technology DXG-506V DV Digital...
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
Jan 14, 2009 | Dell Inspiron 5150 Notebook
Ibook screen issues
This is nearly impossible to diagnose via the Web. It sounds like the logic board is at fault, but not necessarily.
Nov 23, 2008 | Apple iBook G4 Mac Notebook
Faint LCD Screen
i`ve heard about this, but in the other 2 situations the cameras were dropped on water, the problem is that the, lcd connector is not making the proper contact with the main electreonic board, maybe your camera was dropped or something hit it, you just have to open it, and check the lcd connector and adjust it.
Feb 10, 2008 | Kodak EasyShare C743 Digital Camera
Faint blue vertical bars on screen
What you see on your screen are retrace lines, it can happen for various reasons. Jut lower the screen voltage by adjusting the knob specified as "screen" on the LOT, this will disappear.
Jan 27, 2008 | Sharp 32R-S50 32" TV
Video Cameras Logo
125 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
