Question about Whirlpool Refrigerators
The wall between the refrigerator and freezer is extreemly hot!! The rubber seal is so hot that it is becoming flat.
  • Whirlpool Master
  • 1,606 Answers
Pull the refrig out and remove the rear panel . Check the fan motor which cools the compressor , for any obstruction . If not running , and no obstruction , replace . Also check the coils in front , to make sure they are clean from dust , pet hair , etc .
Posted on Oct 01, 2009
  • Mike Smith
    Mike Smith Oct 01, 2009
    Be sure to re-install the panel , as this directs the air flow over the coils and compressor .
My bottom freezer has a sheet of ice on the bottom
Check your rubber seal around the freezer door...has the door become easier to open?....is the seal in good condition all the way around, meaning that you are getting a good seal all the way around the door? If not, you will need to replace it.
Nov 04, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
We have cracks forming in an 8 inch section of
you can use a hydraulic adhesive or Automotive door trim glue ( yellow) works great too these are made for extreem weather conditions ,
Aug 29, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
My frigidaire refrigerator is sweating on the inside. what should i do? its a one door model with ice maker and freezer on top. i don't remember the model. 5 years old.
High humidly could cause condensation or the magnetic seal could be bad.
A couple of things to try;
The easiest thing to do first is to clean around the rubber seal very good with mild soap and water and the metal which the magnetic rubber seal contacts to seal the door. If you find a crack or a deformation of the seal it will let condensation it the refrigerator.
Does the freezer auto defrost or is a lot of ice bult up around the freezer walls? If so manually defrosted the freezer.
Dripping from the Ice maker water supply?
Jul 15, 2009 | Frigidaire Refrigerators
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Possible fire hazard
we have same one ours gets warm but not hot enough to discolor you better call for service immediatly definate fire danger good luck
Mar 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
54 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
