I have just moved into an apartment with a wall mounted cozy heater. I can get the pilot lite to come on but can't seem to keep it on, the instructions are long gone for the heater and i was wondering if there is a place to get them. I push the dial in for the pilot, lite it, then I need the next steps to keep it going. If i try to turn the dial to the on position the pilot goes out.
  • 10,865 Answers
You should keep it in pilot light mode for about 5 minutes until it warms up, then switch it over. Your gas provider generally has a free service whereby they send out a technician to light the heater and make sure it is operating safely. Give them a call.
Posted on Oct 01, 2009
I have a cozy model cdv255 direct vent wall furnace and the pilot light keeps going out. What causes this
dirty fuel line.have see where spider web is enough blockage to cause this. but aslo have found that the thermocouple needed replaced.
Jan 08, 2015 | Cozy Heating & Cooling
My pilot light will not lite. Just replaced the the water heather control a year ago cause i was having the same problem. Worked fine until a few days ago.
The ignitor probably needs replacing. This seems to be a common problem with this particular model. You'll have to order one directly from Cozy.
Mar 14, 2011 | Cozy (W352E) Heater
Have problem with w355 f cozy wall heater won't turn on with pilot light working. Sometimes if I bang on the valves control it will lite up.
need to clean out pilot orifice, unscrew the silver tubing from the pilot and a 1 inch long orifice will fall out, clean by either blowing air or a clean out bit, if there is just a small amount of dirt or debris that comes from the gas this will reduce the amount of voltage to the valve.
Dec 27, 2010 | Cozy (W352E) Heater
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
Pilot keeps going out
The pilot assembly, pilot oriface, and pilot burner should be cleaned and the thermocouple replaced.
May 01, 2009 | Heating & Cooling
Gas Wall heater worked two days ago...now the pilot won't ignite. Any suggestions? I replaced the battery already...that did not do it!
There is probabby a hi limit on the heater.There is on two things I know to keep pilot from liteing.If the hi limit isn't out then the thermocouplen is bad.
Mar 14, 2009 | Desa International GWP20T GLOWARM Wall...
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Rinnai wall heater won't lite.
You may need to take the pilot assembly apart and clean the pilot orifice. If the pilot does not stay lite you may need a new thermocouple. Good Luck.
Mar 29, 2008 | Heating & Cooling
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy one sided wall furnace (no blower motor)
This is a weird one, but make sure all the wire connections are in the correct place. I accidentally miss wired a heater like this and it did the same thing.
Nov 27, 2007 | Cozy (W352E) Heater
Heating & Cooling Logo
99 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
