Question about Kodak EasyShare M863 Digital Camera
Kodak m863 wont turn on and it doesnt charge either.Pls help!! battery and camera are in good state though.
Please help me in my kodak digicam, every time i turn it on , the digicam is automatically shutdown.... please help me
Make sure your battery is fully charged, clean the contacts on the batteries and inside the camera
If that doesn't work, try the suggestions on this site:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html.
If none of those suggestions work, it could be a jammed lens. Try these steps:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though the web page is titled "lens errors", it applies to stuck lens, also.
Good luck, hope this helps, and please rate this answer if it helped you.
Aug 30, 2010 | Kodak EasyShare M863 Digital Camera
My camera battery ran out and when i plug it in to charge it with the original charger nothing happens at all, cant switch it on and it doesnt charge, it wont do off the computer either, i tried it with a...
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
May 27, 2010 | Kodak EasyShare M863 Digital Camera
When turned on I get a red light and a msg that says date and time reset but it won't do anything M863 Kodak
If the camera still remains on after asking for the date and time. Sounds like there is a firmware issue w. the camera. However KODAK doesn't provide a firmware update on the website.
So you will have to send the camera in in order to solve the issue.
However if the camera turns off:
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 24, 2009 | Kodak EasyShare M863 Digital Camera
M863 LENS WILL NOT EXTEND AT SWITCH ON
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare M863 Digital Camera
Everytime i turn on my camra it turns off again
Remove the battery
Contact KODAK:
Oct 04, 2009 | Kodak EasyShare M863 Digital Camera
My kodak m863 wont let me view pics or take them
If this is a No power issue:
Remove the battery
Contact KODAK:
Oct 03, 2009 | Kodak EasyShare M863 Digital Camera
I have a Kodak M863 camera and it wont stay on
If your cam use manufactors rechargeble batt.:
Remove the battery
Contact KODAK:
Sep 29, 2009 | Kodak EasyShare M863 Digital Camera
My camera when swited on will switch its self off straight away
Its the lens that is faulty. Cam is designed to shut-off automatically when it is experiencing struggle extending or retacting the lens. Lens doesn't extend while reviewing pictures that is why it is not shutting off.
You need to send the camera for warranty.
Process it @ www.kodak.com/go/stepbystep
Or call Kodak Technical Support 1-800-235-6325 Ext #1 For English #12 Camera Dept. #2 For Service and Hardware Dept.
Thanks,
Lester
Sep 11, 2009 | Kodak EasyShare M863 Digital Camera
Lens wont stay open.
Remove the battery
Contact KODAK OoW repair is 48,44 +shipping to the repair centre:
Aug 03, 2009 | Kodak EasyShare M863 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
334 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
