WE have a logic 22W TV. Ww have had skylink installed but cannot now access this. How do we reinstall this on the TV please?
How do i reset the keypad
Refer to the answer of question, "If I take out the battery on my skylink sc-100 does it reset it back to factory settings."
Aug 23, 2013 | Skylink Group Skylink Sc-100 Security...
Chimes don't always work. The test button always causes chimes. The door opening, even though the red light blinksks
The problem may be caused by inappropriate installation of the magnets. Read carefully the installation instructions.
Note that as mentioned in step 3, they should be no more than 1cm (3/8 inch) apart, indeed the closer the better. Also ensure that there are no other magnetic source or components nearby.
Mar 09, 2013 | Skylink Group Skylink Security System Kit
I guess the question is about the control panel SC-001.
If power is totally removed (disconnecting DC jack and removing battery) from the control panel, user settings will be restored to factory default. These include all passwords and zone settings. Master PIN will be reset to "000" and secondary PINs will be deleted. Home, Away, and Night sequence default zone setting can be found in the manual.
However, all programmed sensors and remote controls will remain intact. This means that all programmed sensors would still trigger the control panel if activated. And programmed remotes would still operate the control panel. To remove installed sensors or remotes, simply disconnecting power will not work. User must follow instructions in the manual to remove sensors or remotes from a zone.
Feb 19, 2011 | Skylink Group Skylink Sc-100 Security...
Remote code required for a Samsung PS 42A457 television
The only codes i can find are 0088 and 0089, for the minute .welli`ve been through most thingsbut try those two first.
Hope i`ve helped
Dec 05, 2009 | Skylink Group Skylink WS-100/WS-100N...
General Electric USB phone not working
You can download Skylink from this link:
http://www.home-electronics.net/ge/pc/skype_exe/SKYLINKSetup.exe
Sep 29, 2008 | Lands Phones
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
