I cannot get the washing machine door open at the end of the cycle.The cycle has completed but the door lock is still on. I have swiched off the power and checked the filter but it is still locked.
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
As long as no water is in machine the door should open, if not looks like door interlock swith faulty
Posted on Oct 01, 2009
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Everything works but it does not spin
    There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue. Click on the link below for the complete and detailed procedure.
    Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
    Dec 29, 2010 | Frigidaire Affinity ATF7000E Front Load...
    I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
    The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
    Sep 01, 2010 | Samsung WF206ANS Front Load Washer
    Door will not close
    Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
    Thank you !!
    Jul 09, 2010 | Frigidaire ATF6000ES Front Load Washer
    Can't get the door open
    Thank you !!
    Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
    Door lock light is on door is not locked and
    Thank you !!
    Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
    Frigidaire affinity door will not lock when door is closed or register door is not closed when open
    Apr 21, 2010 | Frigidaire ATF6700F Front Load Washer
    Washer door won't open (hotpoint first editon 800)
    I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
    Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
