Posted on Oct 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HI, WE HAVE A SAMSUNG SF560R FAX MACHINE AND THE DISPLAY IS SHOWING ONLY SMALL SQUARES ON IT?CAN YOU HELP?
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Oct 01, 2009
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006227
Points
9738
You have a bad low voltage power supply which is not available for purchase. Sorry
Samsung scx3405f compatible toner
hello . i have a samsung scx-3405f and i have been refil the cartrige ... after i refiled my multifunction machine say on the display "Not Compatible toner cartrige". i donn`t know what to do to him because i have buy a new cartrige and she tell me the same thing. please answer to [email protected] ... tks verry mutch
How can i disable the fax function on my samsung sf-3100 so that it's only function is a phone
Press the Rcv mode/Contast button repeatedly until the screen shows TEL then press stop. now the machine will do nothing until you lift the hanset and press start to receive a fax. This has no effect on sending.
Back cover open
There is a sensor on the back of the fax machine inside the back door area. There you should see a few plastic chutes that may have a small movable plastic lever called a actuator. This actuatoer may have come out of its pivot points. The parts usually can be snapped back into place. Check by moving the parts and see if the error message goes off. You must move the chute open or closed while looking at the lcd display. This may narrow down your issue.
1helpful
SF-341P
Remove all papers from the machine, unplug it from the mains suply and try all over again,
If the problem persist most probably there is a broken or an unplug actuator sensor inside the machine or in the scaner area.
GOOD LUCK.
Fax machine wont work
ur machine nothing problem just plug off for atleast 3 hour then re proge genral setting its wii b ok
3answers
Samsung SF560.
Check if there is a fuse in place (usually fitted to the front edge of the cartridge) and always replace when refilling.
k24674
ADMIN Andrew
ADMIN Andrew
