Question about GE Monogram ZE1660SA Microwave Oven
Microwave appears to have no power. Display is blank. Checked and found internal fuze blown. Replace the fuze with 20A ceramic fuze. Display works. When try to cook something, microwave runs for about half a second and then oven stops and the display goes back to blank. Probably fuze is blown again. What part could be bad to cause the internal fuze to blow?
  • 574 Answers
You have a short somewhere. Possible causes, defective interlock switches for the door,shorted capacitor, shorted diode, defective triac. More than likely its one of these.
Posted on Oct 01, 2009
Testimonial: "Thanks. Sounds like I have some hunting to do to find the electrical short."
Microwave KCMS 135H, makes loud sound followed by blown fuse.
either the high voltage diode,capacitor,or the magnetron tube is dead shorted,remove the leads off the magnetron tube,but check the diode and capacitor with an ohmmeter to check these for a shorted condition before trying a new fuse,if it builds high voltage then its the mag tube
Jan 07, 2013 | KitchenAid KCMS135 Microwave Oven
Can I replace an internal thermal fuse in my jmc7000 jenn-air microwave?
It doesn't have a thermal fuse, but it has a 20A ceramic fuse and on or around the magnetron it has a thermostat.
The 20A fuse (if blown) can be had in local appliance parts store, and places like Lowe's Home Depot, and Wal-Mart.
For the fuse and/or thermostat, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If the fuse is blown and it blows again, it may be a loose fuse holder, shorted high voltage capacitor, or door switch trouble.
If the thermostat failed, it's due to a magnetron overheating due to the internal cooling fan's not working, or just the magnetron itself going bad.
As a bonus, you can find your owner's manual online here free.
If you need further free help, let us know.
Oct 06, 2011 | Jenn-Air JMC7000 Microwave Oven
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ok , I replaced the fuse checked all connections and checked plug for power ! Still my lg lmv1630st will not show any power at all . What gives?
by replacing the fuse you meant the house circuit fuse or the microwaves internal fuse? and by conncetions your talking the internal wiring inside the case of the unit or wiring from the plug? if not its your 15 or 20 amp ceramic fuse inside the unit,if thats blown replace,but chk h.v.diode,v.v. cap,triac,control board, mis-adjusted interlock safety door switch,and lastly the mag could be defective
Aug 15, 2009 | LG Over-the-Range Microwave
My sharp carousel II microwave doesn't seem to have power. I checked the power source and that seems fine. Is there an internal fuse?
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad?
We have the relevant service / repair manuals for this model and have uploaded it to our site here and here to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open these documents automatically, but you may need the free Adobe Reader
I would suspect the 20A ceramic line fuse or the magnetron temperature fuse.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
20A ceramic fuses are available at local appliance part stores or places like Wal-Mart and Lowe's.
Jun 03, 2009 | Sharp R-1870 Convection/Microwave Oven
Emerson MW8106W Blew internal 20A fuse.
You almost certainly have a shorted high-voltage capacitor.
Here is a link you or someone you know can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Oct 19, 2008 | Emerson MW8106W Microwave Oven
GE Monogram ZE1660SA Microwave Oven Logo
467 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
