Question about BenQ Computers & Internet
BenQ fp567 goes on a flicker mode and will not respond
With in the last week my monitor goes gray and starts to flicker the BenQ logo and will not respond to any of my commands with either the monitor or computer, Shut down does no good. I have found that if I move the monitor around it comes back on. But lately it is happening regularly and also with each sign on.
  • BenQ Master
  • 32,281 Answers
The fault could be a faulty inverter or a faulty CCFL lamp.
The inverter supplies high voltage to the CCFL lamp, if faulty the CCFL lamp can flicker or not light up. The CCFL lamp is a mini fluro lamp, and flicks on and off when faulty especially as it ages.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Oct 01, 2009
    Sergeant:
  • 199 Answers
Hi, dude .
Pls get  your technician to check the motherboard for any dry joints  because as you said when you move it  around it responds .
there's  must be some components loose on the board .
He should see that  all wire connectors  alright.
good luck
4 Suggested Answers
ChadL777
  • 69 Answers
SOURCE: monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
Posted on Dec 24, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
Fix-4U
  • 293 Answers
SOURCE: Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Posted on Oct 04, 2008
I have a new BenQ G2220HD monitor connected to my MacBook as an external display. Since I've had it, it's had problems such as flickering pixels, lines that flicker, screen goes gray and flickers and is...
Your onboard video card is going bad on you computer. Some shops may sale an external video device which can be installed in place of your onboard video and it will fix your problem. Average costs aer about $50. Before you try YET ANOTHEr monitor, please try to hook the computer up to a tv to see if the problem pesists, if so, it is time for the above video adapter
Jan 28, 2011 | BenQ G2220HD Monitor
My monitor is a benq T502, and it just started blinking. It shows the benq logo, but it goes down a starts again.
Hello, sergio, hi, check first your PC, this might be a power supply problem or a memory failure, use another monitor on your PC and see if the symptoms occurs.
Apr 06, 2010 | BenQ Computers & Internet
I bought a Lenovo S10e last week, for my mum, the monitor was to small for her, so today I bought a Benq g2220hd monitor, problem is that I dont get a signal on the Benq monitor, I did get the windows logo...
first i would check the compatibility of the monitor to the laptop and see what they say, and if it should work odds are the monitor will have to be set manually through the laptop itself or on the menu of the monitor itself, may take a while playing cat and mouse but im sure you will get it, more then likley from what im understanding its a resolution issue between the monitor and the laptop, especially if you got the windows logo on the boot
enjoy
Jul 06, 2009 | BenQ Computers & Internet
Fp567 replaced bad capacitors resoldered has backlight no video
Check the connections at both ends of the cable to the LCD. If you've damaged the cable you can probably find a replacement on the world's most popular auction site.
Jun 30, 2009 | BenQ FP567 (White) 15" LCD Monitor
BenQ LCD Monitor FP567, no display.The Green Led flicker,but no image.Please send us some tips
dreaded inverter board problem..here is a tip on where to look inside your lcd as is similar models...http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Mar 03, 2009 | Computers & Internet
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Monitor Flickering
If you have some electrical equipments like CVT, UPS near to your monitor, please put them away. If the flickering is due to the maganetic interfearence then it will solve your flickering of screen. and even after this if you are not able to use your monitor buttun then please call your technical expert b.coz your monitor may got some physical problem.
Thanks
Iqbal
Mar 08, 2008 | BenQ FP567s 15" LCD Monitor
Computers & Internet Logo
389 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
