My servis machine doesnt spin, what should i do?
    Genius:
  • Washing Mach... Master
  • 1,467 Answers
Try checking / cleaning the filter
Posted on Oct 01, 2009
My servis easi logic 1400 doesnt switch over in cycle.
Check the control card for dry joints. This is a common problem with these machines
Jul 04, 2009 | Washing Machines
I need instruction manual for servis m6723w
if theres 4 buttons on facia they are from left to right pre wash extra rinse spin cancel and start depending on which button is flashing you may have a problem if the dial is at 12 oclock and the start button is flashing set the dial to any program and the light should stop flashing if it does not you will need a new board for it and it will need resetting with a servis hand set as servis are now no longer you may have a problem... hope this helps
Jun 26, 2009 | Washing Machines
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
My servis washing machine turns and empties but wont spin machine isnt spinning
I suggest you remove motor and check the carbon brushes fitted at the end of the motor, if they are less than 2-3mm long ,they need replacing.
Plz rate my solution
Thanks.
Jan 04, 2009 | Tricity Bendix AW1000W Front Load Washer
Servis easy logic 1600 wont spin
servis easy logic 1600 wont spin just moves the drum half a turn and stops but repeats all the time
Aug 17, 2008 | Washing Machines
Servis m6160w logic 1600 tripping rcd
many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
Aug 10, 2008 | Washing Machines
I have a servis easi logic 1500 washer dryer....i do a lot of loads daily and just all of a sudden my washing machine is not spinning or draining amy water ....it was flowing out of the bottom of the...
HI THIS SOUNDS LIKE IT COULD BE THE CARBON BRUSHES IN THE MOTOR SO YOU NEED TO CHECK THEM OR GET SOMEONE TO DO IT FOR YOU IF THEY ARE LOW (APPROX 5MM LONG OR LESS) THE MACHINE WILL TUMBLE BUT WONT SPIN IF THEY ARE LONGER THAN THAT THOUGH IT COULD WELL BE A CIRCUIT BOARD PROBLEM WHICH UNFORTUNATLEY IS A COMMON PROBLEM WITH THIS BRAND IF THIS IS THE CASE BE PREPARED TO SPEND A LOT OF MONEY ON A REPAIR AS THEY ARE EXPENSIVE!
Jul 30, 2008 | Washing Machines
Have a Servis 1500 Easilogic washing machine. Decided last night that it won't do the spin cycle. Any ideas? Many thanks! Peter.
i used to deliver servis machines and exchange faulty ones, the most common problem was the regulator (the wash selection dial) they are not very sturdy and frequently break down. have you tried just a spin, without a wash.
Jul 01, 2008 | Washing Machines
Servis easi logic 1600 washing machine not working
my servis eai logic 1300 will not rotate half way through the wash but will still spin and dry etc please advise.
May 09, 2008 | Washing Machines
Servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
