Question about Riso Office Equipment & Supplies
Riso Error T01-520 Drum Stuck
Hi I have a T01-520 error on my Riso RN2550. I changed the colour drum over to one that has not been used in a while and now it will not work and just errors when it goes to make a master. It also will not release the drum. I have tried looking through the service manual, rotating the drum manually and holding the little release switch under the drum to unlock it and it still will not pull out and stay locked! Please help!!
  • info57690 Oct 01, 2009
    Hi, I can't see any other numbers on the error code. The machine was working perfectly until i put this other drum into the machine. Is there any way I can get this drum to release so that I can put the other one back in to see if it helps? Could it be something with this drum that is stopping the machine motor? I picked this machine up second hand so don't want to have to call in a service guy and would rather try and repair. Should I be able to rotate the drum from under the scanner unit? at the moment it wont budge!
    Hi I have gone into the service menu and tried to release the drum using service number 556 but it is missing from the service menu. It has 555 and then goes to 557!. I also can't see the pins to see if they are damaged. Any further suggestions?
    Guru:
  • 1,326 Answers
Try unplugging it for 5 minutes and letting it reset, this usually works for most electronic devices that dont have a manual reset...
Posted on Oct 02, 2009
  • Riso Master
  • 19,396 Answers
T01-520 is not drum stick. All the All 520 errors refer to main motor lock/ motor limit sensor faults (T01 is fault that requires maintenance). Drum error is T01-520-520. In your case 520 is the problem code, not the area code. It is not the drum stuck, it is the main motor because there is a fault.
Replacing drum won't help , since the fault concerns the main motor.
It would be useful to know if there is an area code after 520.
Print this out, and read here how to check new Riso codes.
Posted on Oct 01, 2009
  • Ginko
    Ginko Oct 01, 2009
    The drum does not release because the motor is not working.Check the drum connector on the drum side and machine side to see if there are any pins damaged.
    To release the drum you have to go to service mode and use code 556.
    to get to service mode you must hold the print position buttons < > down while you turn on the printer at the same time.
    I must warn you that doing this procedure there is risk of more damage. Riso reccomends calling a technician when you get this code.
    Before attempting service mode, try disconnecting power for two minutes, and power cycling the copier (restart it).
    Regards.
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Colour Drum Stuck
Underneath the drum, in the front, is a little
Apr 10, 2014 | Riso RZ220 Duplicator
Riso rp error t98-526
526 Drum set safety switch is ON, but drum connection signal is OFF.
try to remove the drum and re-install it. hope to be of help
Feb 25, 2013 | Riso RP 3700
RISO RZ 990 Error code D17-237
i think your copier was not used for a long time , so the nozzles inside the drum unit are dry and blocked and you are getting d17 -237 , that over ink on one side of the drum and not evenly covered with ink . you need to take off the drum unit and if possible open it , take off the film , and get inside and clean the nozzles . if not , you will be forced to change your drum unit .
Jul 28, 2012 | Riso Office Equipment & Supplies
Riso- RZ220 codigo de error 18-531, el cilindro no se puede sacar .
The error code should start with a letter. Is it 'P'?
Error P18-531 means: Print drum lock is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Check te solenoid! Maybe it is defective or only stuck.
Mar 01, 2011 | Riso RZ220 Duplicator
In riso v 8000 can we use mono colour like black
Yes, it is possible to use only one print drum regardless if black or color. You choose freely between drum one or drum two. You are also free to insert each V8000 drum into the place you want.
Dec 25, 2010 | Riso RZ220 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Jan 03, 2010 | Riso RZ390 Duplicator
Drum stuck RISO RN2235ui
assuming you have a RN machine
you should of removed the master on the drum by hand if it was not used for more than a couple of weeks, and wipe dry under the clamp.
To get the drum out, hinge up the top of the machine over the top of the drum there is another small door, it hinges up like the top of the machine.
At this point ensure that the drum is in the home position i.e the clamp of the drum is at 12:00 (on top). if not turn drum to that point by hand.
Then try the button again to release the drum. If that fails there is a small **** under the drum at the front door area. there is a catch there that holds in the drum which you can move to the side with a flat screw driver.
May 14, 2009 | Riso RZ220 Duplicator
Riso GR3750 T1 error Drum Jam
I had this problem too: just unlock the hook under the drum; disengage the drum then pull out the drum; then check the home position if not in position open the behind cover, pull the belt until you get the puller to the home position. You will get the same problem if you will not put the main drum puller to the home position. chimuntu@yahoo.com
Aug 06, 2008 | Office Equipment & Supplies
The hook is located just above the power supply once the back cover is off. Also there is a drum release centered under the drum that a screwdriver can disengage.
Apr 21, 2008 | Office Equipment & Supplies
713 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
