Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Can the travel limits on a Chamberlain security+ be reset?
My brother decided to work on my garage door opener while I was away. Now my travel limit adjustments are all out of whack. The door wants to travel down and up way too far. Is there any way to reset the limit screws to where they were when the opener left the factory? I can make the neccesary adjustments from there.
    Sniper:
  • 98 Answers
If you are at the back of the operator looking toward the door the limit adjustment should be on the left hand side.
The adjustment closest to the door is the down limit turn that 3 turns clockwise. The adjustment screw furthest from the door is the up limit turn this screw 3 turns counterclockwise. That should get you close to factor settings. If this does not work; remove the cover on the operator sometimes the limit assy. come apart.
Posted on Oct 02, 2009
Hhow to adjust travel
Posted on Apr 14, 2012
    President:
  • 3,197 Answers
There is no way to reset them to where they were when they left the factory but it should be easy enough to do. One turn of the control equals approximately 2 inches of trolley travel. If the door opens too far then you should be turning the control in the opposite direction of the arrow printed on the cover. Same for the down limit. Some tweaking will be needed I'm sure.
Posted on Oct 01, 2009
How do i set the travel limits on my craftsman garage door opener 139.53919
  • Open the garage dooricon1.png fully by pressing the wall control button. The bottom section of the door should be right at the header in the "full open" position. If it is too far back, the door cable can become misaligned. If it is not back far enough, you may not be able to get your vehicle in and out of the garage.
  • 2
    Position a stepladder behind the garage door openericon1.png motor. Locate the limit adjusting screws on the left side of the motor housing. Have a friend stand by the wall control button.
  • Sponsored Links
  • 3
    Insert a screwdriver into the slot for the "up limit" adjustment screw. Turn it to the right to decrease the door travelicon1.png and turn it to the left to increase it. Turn the screw in small increments.
  • 4
    Close the garage door by having your helper push the wall control button. Notice the seal between the door and the floor--there should not be any light coming through. Adjust the "down limit" screw in the same way if necessary.
  • 5
    Operate the door by the pressing the wall button and check your adjustments.
  • Read more: How to Adjust a Craftsman Garage Door Opener ' eHow.com http://www.ehow.com/how_5419011_adjust-craftsman-garage-door-opener.html#ixzz2Hm1tx0a0
    Jan 12, 2013 | Sears Craftsman LiftMaster Chamberlain...
    Press the button for the garage door to go down and it will only travel a couple of inches and shakes. Unlatch the door and press the button and the door will catch the latch on the way down and close. ...
    Most likely cause is the load limiters. Firstly, the door needs to work perfectly, when worked manually. No stops or restrictions through entire movement. Then reset the load limiters to spec and test again. Up limit is not extremely critical, but the close load limit can save lives and prevent vehicle damage.
    Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
    MY GARAGE DOOR KEEPS OPENING AND CLOSING. AND ONE OF MY SENSORS IS ORANGE INSTEAD OF GREEN. WHAT IS THE PROBLEM?
    As I have mentioned in other post, re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
    Oct 23, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
    Craftsman garage door opener #139.53985 The door reverses in the fully closed position. I can not decrease the down travel limit by turning the adjustment screw clockwise. Please comment regarding a...
    TAKE OFF THE COVER & SEE IF THE LIMITS ARE WORKING CORRECTLY.
    IF THEY ARE AND THERE IS JUST NOT ENOUGH TRAVEL YOU MAY NEED TO REMOVE THE CHAIN AND REINSTALL IT 4 OR 5 LINKS OVER THIS WILL INCREASE THE LIMIT.
    HOPE THIS HELPS
    Jun 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Chamberlain hd900d garage door opener
    You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
    May 20, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
    Chamberlain powerdrive door opener will not move. moter hums but chain will not move
    CHECK TO SEE IF HE TRAVELER IS AGAINST THE BOLT ON THE RAIL. IF IT IS YOU WILL NEED TO LOOSEN THE CHAIN / BELT TO GET IT TO MOVE THEN ADJUST THE TRAVEL LIMIT SO IT GOES UP / DOWN LESS AND DOESN'T HIT THE BOLT.
    HOPE THIS HELPS
    Jan 10, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
    My garage door opener travels settings out of wack ??
    The 'up and down limit' adjustments are on the side of the motor unit.
    Aug 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
    My door opener is new, Chamberlain, mod cg40cd, the drive will hit both limits. will not let me set the up and down limits, doesn't seem to matter whether I set the up and down to max either way??????
    THE TRAVEL ADJUSTMENT IS ON THE SIDE.
    YOU MAY BE ADJUSTING THE SENSITIVITY (TRAVEL LIMIT HAS NO MAX ADJ.)
    BE SURE TO RESET THE SENSITIVITY ADJUSTMENT TO ABOUT 1/4
    HOPE THIS HELPS
    Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
    I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
    Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
    Not working
    IT MAY BE AGAINST THE TRAVEL LIMITER BOLT.
    IF IT IS YOU WILL NEED TO UNPLUG THE UNIT REMOVE THE COVER AND TURN THE MOTOR BY HAND TO BACK OFF THE PRESSURE.
    MAKE SURE YOU GO PAST THE LIMIT SWITCH.
    ADJUST THE LIMIT SO TH DOOR DOES NOT HIT THE BOLT.
    HOPE THIS HELPS
    Sep 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    554 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
