Question about Garden
Machine wont run with choke completely off
Runs great at half choke but dies completely when i turn choke to off position
  • 11,896 Answers
The carb is gummed up and needs to be cleaned
Posted on Oct 01, 2009
Testimonial: "This site is FANTASTIC! I posted a problem at 5:25 A.M. and had a solution within 7 minutes!"
99 Honda Fourtrax will not stay running with choke off. Would this just be a idle adjustment?
No it is not an idle adjustment. You need to remove the carb, and remove both jets ( pilot jet and main jet). Ream the jets with thin wire or compressed air. Hold the jets up to the light and make sure you can see thru them. I believe you will find your pilot jet to be clogged.
Sep 26, 2016 | Honda Motorcycles
Just starting to use this spring, and having fuel starvation issues. I ran it this winter a couple times and it ran properly.
add a little carb cleaner to the gas and try letting it run on half choke for a while longer .
Mar 28, 2015 | Garden
I have an older craftsman snow blower 10 hp. It starts ok with full choke, runs ok half choke, backfires with no choke-run position.
It's too lean; not enough fuel mixed with the air. Look for the main mixture screw--it should be a large screw with a spring under it on the carburetor. Run the engine until it's warm.
With the engine running, turn the screw outward (lefty-loosey) about 1/8 turn slowly and see if it improves. Slowly turn the screw back and forth until it runs best with the choke completely off. Then set it 1/8 turn richer (turn screw outward 1/8 turn) than the best position.
Reason for doing this: Conditions change, even the barometric pressure. Small engines run okay if they are a little rich but not if they are a little lean.
Mar 03, 2015 | Garden
1641 cub cadet how to check fuel shut off solenoid
it wont start at all if the solenoid is unplugged try and see if it will run with the choke about half way on if so you have trash in your carb
Apr 21, 2012 | Cub Cadet Garden
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Wont run in run position
if it runs on choke only and it sat up for two or three months the carb diaphragm may be brittle and not pumping fuel. install a carb diaphragm and gasket kit or try opening the high speed jet a 1/4 turn
Jul 01, 2009 | Craftsman 25cc Gas Line Trimmer
Weedeater wont run
Take the red and blue limiters off to adjust. Back out 1- 1 1/4 turns and go from there.
Jun 22, 2009 | Poulan Garden
Runs rough when choke pushed all the way to run position
Where can i obtain a manual for the 5500 gas generator
Dec 26, 2008 | Coleman Powermate Powermate 5000W...
Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
Nov 23, 2008 | Garden
96 cavalier 2.4 starts runs great -chokes
Check the crankshaft position sensor. If the plug is loose or the sensor itself is bad it will cause similar problems
Aug 23, 2008 | 1988 Chevrolet Cavalier Z24
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
