Question about Sony Playstation 3 (PS3) Console
My ps3 keeps on over heating what does that mean?
    President:
  • 267 Answers
1). Make sure it has 10cm gap around it;
2). Gently vacuum vent holes from time to time;
3). When PS3 is off - cover it with a piece of cloth;
4). Put it in a horizontal position. buy a ps3 intercooler, it about 30 bucks thank you for using fixya,rate my answer
vijay
Posted on Oct 01, 2009
Nba 2012 keeps freezing
bad cd game , if all other games play ok , this means the nba game is not good
Feb 20, 2012 | Sony Playstation 3 (PS3) Console
My ps3 says correct hard disk was not found. what does that mean?
iM NOT SURE TAKE YOUR HARD DRIVE OUT THEN SLOT IT BACK IN AGAIN IF NOT HARD DISC HAS BEEN OVER HEATED .. Tip: do not keep playstion on carpet :) overheats
Oct 14, 2010 | Sony Playstation 3 (PS3) Console
After playing for a while the fans in the consol speed up and make alot more noise than usual this hasnt happened before.
allways put ps3 in a good ventillated spot away from heat ;radiator soforth ;could be over heating i put a fan blowin on it to keep cool '
May 02, 2010 | Sony Playstation 3 (PS3) Console
Hi, my ps3 keeps turning off and the red light comes on and flashes real slow. what does this mean ? it crashed mid game
Your system is getting hot, try using a vacume to clean the vents out, also buy an aftermarket intercooler.
When the PS3 gets over heated it will shut off regardless of what you are doing to preserve its self
Sep 28, 2009 | Sony Playstation 3 (PS3) Console
I was playing the bigs 2 when suddenly my ps3 started to shut off.I turn it on again it wont turn back on.The red light just keep on blinking.
Turn the PS3 power off via the switch on the back.
Hold the power button on the front of the machine down for about 15-30 seconds.
Then, without letting go of the power button on the front of the machine, turn the switch on in the back.
If it still doesnt come on then you may have serious problem with PS3 in which contact Sony or the retailer you bought it from for exchange or rapair.
Jul 27, 2009 | Video Game Consoles & Games
AHH
THIS CAN BE SOLVED IF YOUR PS3 IS OUT OF WARRANTY
The yellow flashing dot of death does normally mean that your PS3 is Dead but there is a way to fix it
My PS3 would not start and the indication light just flashed between yellow and red
Your options are: New PS3 £250, PS3 from Sony second hand £150 or £5 fix
1. Undo the screw below the warranty sticker in bottom of PS3
2. Slide the lid of
3. Remove all bolts
4. Remove all main components until the mother board is free from the unit
5. Remove the thermal gel on the back of the 2 main chips to the heat sinks
6. Clean any excess dust by blowing away do not use and dusters or leky equipment
7. Level up the m board and heat over all the board with a heat gun, needs to be really hot to melt the solder but not damage the board or components
8. Allow to cool and turn over repeat the above
9. Buy some thermal gel online and replace the gel removed of the chips using a credit card
10. Once cool after 15 to 20 mins replace all the components and PS3 Lid
11. Run a fan test on your ps3 (turn of at the back hold down the eject disk button and turn back on keeping the eject disc button held down until fan starts)
12. Turn you ps3 on and bam your back on COD or FIFA (add wadhapa)
Hope this is of some help but this is only recommended if your PS3 is out of warranty and you are not sending it back for a Second hand Sony one
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
Ps3 is quitting by itself
Your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up.
May 16, 2009 | Sony Playstation 3 (PS3) Console
Red light flashing/won't turn on
you are right about replacing the thermal compound between the cpu/gpu and heat sync. the gpu and cpu may need to be refolowed also. another tip is dont over tighten the screws. Tip: keep your ps3 flat do not keep it standing. when it is standing and heats up the thermal compound can start to move away from the heat sync. Keeping it flat will help extend the life PS3 at least from the overheating issue.
May 14, 2009 | Sony Playstation 3 (PS3) Console
Ps3 keeps staling
Just like the X box the heat transfer emulsion on the chips to heat sink wears out, dries out, flakes off, and cannot transfer heat any longer. I would imagine it is over heating. There are MANY youtube videos that will walk you through the process. Dont use the cheap heat sink compound. Use the 98% silver. You can find it @ The shack. Not to hard to do if your a little handy.
Jan 01, 2009 | Sony Playstation 3 (PS3) Console
Ps3 keeps overheating and i already have an intercooler
my ps3 keeps freezing evertime i finish a game of mw2 or ten minuits into another game of something but when i feel the bac of my ps3 it is letting out lots of hot air does this mean it is over heating or is it my fn has broke or something because it is anoyying when u have a good game and it frezzes so u dont get the points :@!!!!!
May 09, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
