Question about Sony RDR-GX300 DVD Recorder
Cannot get Sony DVD recorder to record from my V+ BOX
Cannot get it to record from my V+ BOX, LINE 3 is not selectable from the input select options and will not record through line one, just get green screen or audio and no picture depending on which scart lead I use.
Hi Charliegeorg,
Did you get this fixed?
I have same problem. Worked with my Sky+ at house, now in my flat, the same doesn't work!
Cheers
John
Posted on Dec 12, 2009
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
Cannot get picture/menu on screen!
The Sony recorder is connected to the TV via the RCA cables (for both audio and video)? How many inputs does your TV have? One cable input and one RCA line in (making a total of two? Did you eliminate the possibility that the recorder might be defective by trying it on another TV?
Dec 25, 2007 | Sony RDR-VX555
Appears to be recording but is not. The player
Hi
Does your dishnet box have two tuners or one, if only one then only the program being watch on the tv can be recordered , this will have to be connected to the av input on the recorder and one of the av (line input) selected with the remote control for the recorder, If the dishnet box as two tuners then the output from one tuner can be used to feed the tv and the other one will go to the recorder connected through the av input. hope this will help regards windyhouse
May 11, 2010 | Toshiba DR410 DVD Recorder
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Jan 02, 2010 | Mitsubishi VS-55707 TV
I have installed a converter box we have a rooftop antenna, now I cannot record, it does not seem to find channel 9.1, 12.1 etc only 9, 12 etc I went from antenna to converter to DVD MWR10D6 to TV. My tv...
If you have the converter connected to the recorder by composite or s-video(line inputs), you will need to specify which jacks from within the setup menu of the recorder. There are 2 sets of line inputs into the recorder, so you have to select the right ones. They are called L-1 and L-2. The L-1 jacks are in the rear and the L-2 jacks are in the front. The channel selection should also be on L-1 or L-2. If you are using the
RF input(fat cable) to the recorder, you should have the recorder on the channel number that matches the output of the converter (channel 3 or 4). The converter RF output is selected by a switch in back of the converter or by the setup menu of the converter.
Menu path for setting L-1 or L-2 inputs:
Setup > General Setting > Video > Video Input > L-1 or L-2 > Video In or S-Video In
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Volume control on windows mixer
have you check which input the system is selected for recording it mite be site for the mic not the line in
check this in xp by going to the mixer
click options
click properties
check the box recording
now it should show the recording sliders (check marke the mark the following boxs to see the sliders)
Line in press ok
Put a check in the Linein slider and make sure it selected and turn erup
i also use wave labs and forge and quick basic test if you can record from the mic then its selected as the input
make sure other inputs are down as you will also get feedback from the builtin mic
Oct 08, 2008 | Computers & Internet
How to Record TV Programs w/o Cable Box/Satellite Receiver?
if there are rca ports on the front of the vcr which are output, connect those to the tv input 3, the input to input connection is definitely not going to work...
May 09, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Sony RDR-GX300 DVD Recorder Logo
212 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
