Question about Dell Dimension 4600 PC Desktop
My dell 4600 Dimensions was working just fine. The system locked up and I had to power down. When I tried to restart the computer powered up but there was no boot sequence, no beeping nothing. The green power light is on, the diagnostic lights are blank and so is my screen. Any suggestions?
    Sniper:
  • 51 Answers
If you're familiar on how to open the computer tower's cover, we need to open it.
before opening the cover, make sure all cables are disconnected from the back of the computer. and make sure that you drained the remaining power of the system.
after opening the computer tower's cover, try to locate the cmos battery. (it's a silver coin like battery), remove it from your computer. wait atleast 10 minutes before placing it back. then try to turn on the computer again.
to open the cover, here's the link for the diagram:
http://tinyurl.com/9ax7f
for the complete manual of the system:
http://tinyurl.com/aqzp3
Posted on Oct 01, 2009
  • 329 Answers
Try to open up your laptop and remove cmos battery...it will reset your bios system that help you in systematic booting....if it still doesnt work then provide full information at infoworldcomputer@yahoo.co.in
do reply
I have a dell dimension 4600 it got lockked up dont know how to unlock it. Please help.
Try powering off by holding in power button for 15 seconds. If that does not work, unplug and plug back in the power cable and restart.
Apr 29, 2012 | Dell Computers & Internet
How do i open my Dell dimensions 4600 to install
Just lay it over on its right hand side, there a button on the top and the bottom, press these both at once and lift. It will just hinge up and give you plenty of access. When closing just make sure its lined up and it simply clicks back into place. Cheers from Scott
Feb 19, 2010 | Dell Dimension 4600 PC Desktop
How do I restart a Dell Dimension 4600 PC Desktop
Hello gabeymybabey,
If the computer is using Windows XP, do the following to restart the system:
•Click the Start button
•Click Turn Off Computer.
•Cick Restart
The computer will restart after the shutdown process finishes.
Also, here's is a link to the Dell 4600 Series user guide:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/index.htm
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jan 31, 2010 | Dell Dimension 4600 PC Desktop
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
Cannot reformat Dimensions 4600 I tried F11 but it won't let me restart
If you are going to reinstall the operating system on the dimension 4600, while it is on insert the Operating System CD inside the drive then press and hold the power button to turn off system. When you turn it back on press the F12 Key once on the Dell Logo and that will take you to the Boot Menu. Choose the one that says IDE or Onboard CD / DVD Drive then press enter. If it asks you to press any key to boot to the CD then press enter again. Then just follow the normal prompts for reinstalling the operating system.
Apr 05, 2009 | Dell Dimension 4600 PC Desktop
My dell dimensions 4600 will not boot
Dont worry.This can be resolved.Goto the BIOS by tapping the F2 key on the restart -Goto the option which says Maintainence>>Event log>>Clear all even logs -Now press F10 to save and exit or press the ESC key just once and Select SAVE and EXIT
Mar 17, 2009 | Dell Dimension 4600 PC Desktop
Dell 4600 usb ports not working
Have you gone to Start>Control Panel>Device Manager to see if there are any yellow exclamation marks in front of the usb devices?
Oct 25, 2008 | Dell Dimension 4600 PC Desktop
Replacing Dell Dimension 4600 Internal DVD Drive
1. make sure the connections are tight.
2. restart ur system..on dell logo press f2 key..
3. once in the bios screen...press num lock caps lock and scroll lock..make sure all 3 are on
4. press alt and e together
5 press alt and f together
6. press esc
7. select save changes and exit
ur system will restart...it should make the dvd rw get detected
Jan 31, 2008 | Dell DVD-ROM for Dimension (6t903)...
Hard drive and cd drives still on
Locate Power Wakeup option in modem/LAN in BIOS and disable them, if you have "power wake up" enable for LAN/modem your computer will be switched on for remote network command.power wake up setting are located on BIOS.
Dec 09, 2007 | Dell Dimension 4600 PC Desktop
Problems with dell 4600
Try to open it in safe mode. If it opens and don't reboot then right click on my computer->click on properties->click on Advanced Tab->setup and recovery framework click on settings->in system failure framework remove checked from Automatically restart.
Oct 23, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
196 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
