Question about Cameras
I want to transfer tape from my v.c.r. to my camcorder
I want to transfer tape from my v.c.r. to my samsung vp-d381 camcorder,but when I go to menu there is no Av in/out.Windcut plus is were Av in/out should be.Yet my manual tells me it should be there.
Fast tape playback for samsung vp-l770 can't watch at normal speed on camcorder?
Tapes recorded on one camcorder very rarely play back satisfactorily on another machine - you will have to use your old camcorder to view them, or else get them transferred to DVD
Oct 07, 2016 | Samsung VP-L770 Hi-8 Analog Camcorder
I have a Samsung DV-D381 MINI Camcorder. What
OK there are NO cables as such for that PC, as of normal, to get Video into this machine you will have to use either, a USB TV/Video card, and use the AV inputs. OR put a Video TV/Video Capture card into a PCI slot, and again use the AV inputs to connect via. The you will have to use the AV leads Yellow, Red & White, OR the SVHS port if available. You will also need software to record the video stream, If you camera has FireWire then you could install a FireWire Card into a PCI slot and hook you via that, you will still have to use software though. Sometimes the camera, has proprietary software to edit and work with the Video from the camera, usually via FireWire. To get said software go to the manufacturers web site, and download a copy.
Mar 15, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
Got a brand new samsung d381 camcorder and when you playback recordings there are horizontal green lines across the screen and no sound, what am I doing wrong? or should I send it back as faulty? I have...
SOUNDS LIKE YOUR HEAD IS STUCK OR YOU NEED A DRY CLEANING TAPE RUN TROUGH. SOMETIMES WHEN U USE OLD TAPES THEY ARE DUSTY AND THE DIRT CLOGS THE HEAD. TRY A GOOD TAPE CLEANER
May 28, 2009 | Samsung DouCam VP-D5000i Mini DV Digital...
My Camcorder Breaks the tapes
Your camcorder needs to be cleaned and or serviced ASAP. Please do not use any more tapes, as you may have a stuck roller head or sticky contact surfaces that can "catch" the tapes intermittently.
You should be able to have it serviced very cheaply at a camera store, but I would not use it any further for danger of potentially ruining the camera.
Mar 20, 2009 | Samsung Video Cameras
Samsung camcorder vp-d381 eject L fault
YOU CANT CLEAR IT. THIS SOUNDS LIKE THE TAPE TRANSPORT IS BAD. SOMETHING BROKE INSIDE TRANSPORT AND NOW IT WONT ALLOW YOU TO LOAD TAPES
Feb 21, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung VP-D381 Where do you insert the SD card?
The VP-D381 does not have the SD card feature, only MiniDV for recording. I beleive its the VP-D835 that has the memory card capability.
Oct 21, 2008 | Samsung Computers & Internet
Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Where can I download software for my Samsung VP-D103i, to my computer?
where can i down load software for my VP-D103 please, i need to transfer my tape on to PC
Dec 24, 2007 | Samsung VP-D103i Mini DV Digital Camcorder
Cameras Logo
95 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
