Bios setting problem?
Last sunday i change my bios setting 1. load optimal defaults and 2.load fail safe defaults so after that my computer when i start up my computer shows a informatiom "ethernet adapter 10/100 .media testing failure and check cable pre rom exiting" like that error so i want remove this information because my computer not show this type of information before change the settings and i have n o more knowledge about computer show give me help................
  • 329 Answers
Open up your cpu remove cmos battery start your computer for 5-10 secs.. now switch of cpu and put the battery again in it and start compuer again...its will reset your bios setting to factory default.....do reply me
Posted on Oct 01, 2009
  • 284 Answers
Optimal Defaults and Fail Safe Defaults are two different sets of values. If you set one after the other the second would have replaced the first. Try setting back to optimal again.
If you still see errors relating to the Ethernet adapter find the Ethernet adapter in your BIOS settings and set it to Auto. If you still see errors try all of the available Ethernet settings.
Hope this helps you get your computer running again.
My computer is failing to automatically reastart .
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Apr 20, 2013 | Dell Computers & Internet
Attempting to install OSX on WD7500BPVT Hardrive. OSX says HDD is locked.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
if its password protected (locked)
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 14, 2013 | Western Digital 750 GB Scorpio Blue SATA...
My computer wont turn on lights up but wont turn on
What did you do in bios ?
You might have to go back into bios and set fail safe or optimized defaults.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Dec 22, 2012 | Abit AS8 Motherboard
What is the difference between fail-safe defaults and optimized defaults in bios
failsafe defaults are settings that aren't necessarily the best settings for the computer but should work with any operating system, optimized defaults utilize the hardware to it's optimum capability
May 04, 2012 | Computers & Internet
Set up utility?
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
Mar 30, 2012 | Compaq Presario 5000 PC Desktop
I would like to reset it back to factory settings thank you
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart also click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Apr 08, 2011 | Computers & Internet
In CMOS setip utility, I am not able to load fail safe or optimized defaults or set supivisor password.
Try opening up your computer and removing the CMOS battery. Should be the only battery on your motherboard (the thing everything plugs into) this will usually reset your bios. Some bios also have a jumper that needs to be switched but without knowing your motherboard model I can't be sure.
Mar 01, 2011 | Systemax Ascent PC Desktop
Bios settings?
these settings are related for boot up troubleshooting....system need startup point that is called boot up point.. Now there is sequence for search for boot up device that contain boot up point These device consist of floppy drive, hard drive, cd rom, usb drive and lan.....so try to set your boot device priority with hard drive as first device....this will solve your boot up problem....do reply back
Oct 02, 2009 | Computers & Internet
My hp media desk top computer vista will not boot up i get blue screen with some comands and logo hp invent then screen goes to black screen and has this message, reboot and select proper boot device or...
If you have the boot disks that came with the computer this is the media it is talking about.. After you re-load everything to your computer I suggest downloading AVG antivirus
Jul 10, 2009 | HP Pavilion a1700n PC Desktop
Computers & Internet Logo
407 people viewed this question
David Payne
David Payne
