Question about Samsung Omnia Pro B7320 Smartphone
Hangs sometimes during sync.. GPS is not working.. GPRS settings are not available..
  • 6 Answers
Hi
Try Turbo GPS. Install the application and select windows wm5 intermediate GPS driver. If this works you can be very sure that the GPS chipset is not faulty.
The handset takes a real long time to get the GPS fix so be patient and try.
Posted on Oct 05, 2009
My vauxhall insignia sri wont sync the bluetooth to my phone.....when i press the CONFIG button & select phone settings it says not available, I have the CD 300 & my phone is a samsung Galaxy S...
my vauxhall insignia sri wont sync the bluetooth to my phone.....when i press the CONFIG button & select phone settings it says not available, I have the CD 300 & my phone is a samsung Galaxy S I9000
Oct 17, 2010 | Insignia GPS
Hp LJ P3005DN hangs during boot. Sometimes during
It would not surprice me if you have a defective formatter board. This is a very commen problem with this machine. Officialy you have to replace the formatterboard but there is also an other way to fix it. Put the formatterboard in to a preheated oven 190 degrees Celcius (350 fahrenheit) for 8 minutes. 8 out of 10 times it works fine fine and the machine is up and running. If this does not work you still can replace the formatterboard.
Dec 30, 2009 | HP LaserJet P3005dn Printer
My garmin gps 60 csx hangs midway during operation
Have you updated the unit's software lately? Free unit software updates can be found on Garmin's site. Search for your model as this software is model-specific. There was a new satellite launched in '08 which caused problems for some Garmin units, making some units freeze. The software update fixes this.
Please come back and advise us if this works, and rate our solution. Thank you.
Nov 30, 2009 | Garmin GPSMAP 76CSx Handheld GPS GPS...
Change time
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> --> Question Setting the clock Answer To select the type of clock that is shown and set the time, tap Change preferences > Set clock.
This feature is only available on your navigation device. You cannot use this feature in TomTom HOME.
  1. The easiest way to set the time is by tapping the Sync button. Your navigation device will then take the UTC time and date from GPS information.
    Note: You can only use Sync if you have GPS reception, so you cannot set the clock in this way when you are indoors.
  2. Adjust the hours depending on your time zone. Your navigation device works out your time zone and always keeps the time correct using GPS information. You only need to adjust the daylight-saving time.
Nov 10, 2009 | Tomtom ONE XL GB Car GPS Receiver
Dear sir my htc p3400i gprs not working. please give me setting by mail
try using the settings below
GPRS Settings:
Primary IP address:
 216.155.165.050
Port: 8080
Secondary IP address:
 Blank
APN name:
 wap.voicestream.com
Data bearer:
 GPRS
Profile name:
 GPRS
Username:
 Blank
Bearer:
Data
May 11, 2009 | GPS
New blackjack 2
Hi-
Did you set/configure the GPRS settings on the phone provided by your telephone company? they usually have the correct/exact settings for various phones, what i can really suggest is to cal your phone company so that they can give you the settings for the GPRS/GPS for blackjack, since this is a new phone that will be free of charge, since you are still within warranty.
Aug 17, 2008 | Samsung Blackjack SGH-I607 Smartphone
Hw6515 pda
Dear Phil,
its mean you have to update the GPRS Service.
there are 2 ways to downlaod the files, GPRS or internet
GPRS
1. click on the quick gps connetion icon, select setting.
2. select setting, then check the enable update and initial GPRS
3. click on icon and select download, it will connect to date service and download the files.
internet:
step 1 and 2 above
3. click icon select download while it on cradle.
also install the quick gps utility on pc, and add the quick qps connection into activesync list. each time you synchronize PDA the file will get updated.
For your second problem ,which is related to File Passward protections , its seems you had create these Worksheets on NTFS File system thatswhy they asked about the passward.
Regards
Mar 29, 2008 | HP iPAQ hw6515 Pocket PC
Not able to set up GPS in my HTC p3300 in india
It sounds like your not able to access the internet on the device , try going to a normal webpage and then you can check if it loads it most probably wont. if that is the case you will need to contact your network to get the settings. ( Most networks will brand the device with there own name it can be helpful to find what this is before calling .) once you have done this then you will be able to download the quick gps settings . The special GPRS mentioned above is only the networks name for there GPRS service.
After this is done you may notice that you still arent able to use your GPS to find your location that is because you need to select the port that the GPS device is on
1.Tap start > settings
2. Tap the system tab
3. Select the GPS option
4. In the drop-down box that is entitled GPS program port select COM4
5. Tap Hardware tab , Gps hardware port should be ( None ) and baud rate 4800
6. Tap access tab and then select manage GPS automatically tickbox
7. Now click ok then x
You will now need to setup MAPKing to use COM port 4 as the GPS device this will now allow you to use your GPS properly
Feb 18, 2008 | HTC P3300 Smartphone
Ipaq Quick GPS connection file downloads
You may need to use the hard reset to make the quick gps connection working. but you will lost all ur program or data, including smart nav or tom tom. if you ready want to use the hard reset, remember to download smart nav or tomtom program. or you will end out no map in your system. good luck
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
Samsung Omnia Pro B7320 Smartphone Logo
261 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
