Question about Toshiba e-Studio 232 Black and White Copier
A block mark is appeared in the paper
A block mark is appeared on the other side of the paper, when the copied paper comes out of the machine
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; It seem like have pressure roller dirty just use alcohal to clean up.
Posted on Oct 02, 2009
Di 3010 error code dialta SC 520
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that is OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Jun 27, 2013 | Minolta Di3010 Copier
Minolta di2410 c0500 error code
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip for that only :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Jan 22, 2013 | Minolta DI2510 Black and White Copier
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
Line appears down right side of paper when copy is made?
If the line only appears when making copies but recieved faxes come out ok, then the scanner glass needs to be cleaned. Water and a lint free cloth should do the trick.
Sep 15, 2010 | HP 1010 Plain Paper Inkjet Fax
Marks down left side of copy
There are several things that could be causing this I will TRY to address or suggest on all of them.
1.) If only appears when copying, double check the glass and make sure those areas are cleaned.
2.) If happens at all times, it could be the toner cartridge in the unit (especially if started when just changed). I would try another cartridge (later if you can stand the copies w/ the lines or if you have a spare).
3.) I have seen a lot of these machines do this putting vertical lines down the side of the paper because the fuser assembly has worn out and needs replaced.
I have seen #3 occur sometimes when paper gets jammed in a machine and someone pulls it out too rough, this can cause the slick cover over the fuser to crack, break, or bunch up, needing replaced.
Hope this helps you.
Apr 28, 2010 | HP LaserJet 3330 All-In-One Printer
Xerox Copycentre C123 Creating a Ghost Image
First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
Jan 04, 2009 | Xerox CopyCentre C123 Black and White...
Panasonic Panafax UF-885 - Heavy lined marks down side of paper
First print a report to see if the lines appear without using the scanner. If this is the case clean the charge wire. If you pin it down to the scanner, it is probably a poor solder joint on the cis unit. Take it out and run a hot soldering iron over all the joints on the reverse side of the cis.
Apr 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Samsung sf 330
If you open up the feeder door (Where your originals feed into) you will see a slit of glass going from side to side by the feed rollers. (you might need a flashlight to see it better)
On the slit glass there is probably some white out or something on the glass. All you have to do is clean the glass and this should take care of your problem.
To help you zero in on where the marks might be located, make a copy of a white piece of paper through the fax machine.
And then line up the copy that comes out with your black marks to the feeder.
This should get you in the general location.
If you have any other questions, feel free to post another question.
If I have helped you, please post a feedback and a rating.
Have a good day.
Good luck.
Mac
Feb 23, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Jan 03, 2008 | Canon imageRUNNER 400S Copier
PAPER FEED
the drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Sep 17, 2007 | Canon FAXPHONE L80 Laser
Toshiba e-Studio 232 Black and White Copier Logo
63 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
