Question about HP Compaq Presario V2000 Notebook
When the laptop starts it freezes at the Compaq logo. I have rep[laced the RAM and hard drive. Occasionally there are also 2 beeps when it starts up and then it goes to select F1 for boot order (something like that)
  • 112 Answers
I think your hard drive is not set proper so go to shop were u purchase and make sure hard disk is proper working
Posted on Oct 01, 2009
    Sergeant:
  • 199 Answers
What operating program do affect the performance of  machine  so try and remember which program was ok on your machine and install it ,not all  windows will run smoothly in all machines it depends on motherboard architecture .
Install win XP professional  and see if the speed improves .
Good luck
Aspire wont load and beeps
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
Test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
graphics card is seated properly with no dust in the socket you might have to remove it to check for dust
a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
hope this helps
Jun 08, 2012 | Computers & Internet
Whenever I start my computer, it shows the Sony Vaio logo and right after that my computer starts beeping while staying at this logo. Sometimes it starts with windows restore and then it froze there and...
The beeps are a code to let you know what failed during the Power On Self Test (POST)
Count the beeps - and whether long or short. (Like 3 longs and 2 short, etc)
Go online to the Soony web site, or search for Sony POST codes. A list of codes will tell you what is failing - such as ram - or hard drive, etc. I suspect the latter.
Dec 06, 2010 | Sony VAIO VGN-FE770G Notebook
My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Nov 12, 2009 | HP Compaq Presario V2000 Notebook
No display at all
hi,
from what you have mentioned it seems that, it can either be one of the following situation
1) you see the power light, hp/compaq logo and the windows startup logo but don't see any logon screen or desktop
2) you don't even see the hp/compaq logo at startup but only see the power light
1) this can mean your display dripers may be corrupt,
what you should do is restart the system and keep tapping F8 from the moment you see the compa/hp logo when you see a menu you will be given the option to start in safe mode select safe mode and press enter, see if you are able to see the desktop now if yes
just go to start menu >run> type in without quotes "devmgmt.msc" > ok > in here click on display adapters> right click on the entry below it select uninstall > after uninstall retsart the system , now when the system boots the system will detect your display adapter and try to load the drivers for it. now you have to follow through with the hard ware wizard and install the drivers.
2) in this case when the system is not even completing post that means there is some hard ware that is stopping it from post
take out the battery from the system and now try to start the system using AC adapter, if it doesn't work then take out all the external pheripherals attached to the system only if you are comfortable doing that
take out the Ram, hard disk, optical media drive and plugin cards that you have and then try to start the system on Ac adapter
if it does start, put one thing in at a time like
try starting it with RAM in,
then ram and hard drive in
then other things one at a time
and the time it stops posting agian it means the last thing that you have entered is faulty and was not allowing the system to post same goes for desktop
but you can check this only if you are comfortable doing it if you are not then you should check with compaq hp technical support also if you are under warranty don't do it on your own check with their technical support.
Further Queries are welcome
Jan 28, 2009 | HP Pavilion DV5234US Notebook Laptop
'03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
Nov 11, 2008 | Compaq Presario X1000 Notebook
Prosario V2000 boot problem
This means that there is some component was not fixed well.
this error means: " press esc to change boot order"
"press F10 for setup press F12 to boot from lan"
with 2 beeps " that the system cannot find hard drive:
fixed every thing: and try this. if prompted to go setup , continue and find "load bios setup default and then save and exit.
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Can't boot up laptop
problem with ur memory(RAM)
Dec 03, 2007 | Gateway 450SX4 Notebook
If your Usb port works, then the mobo is working, so possible graphics problem. Try booting up in safe mode(normally pressing F8) on boot up then highlight 'start windows in safe mode', to see if Windows will load with only minimal drivers, if so restart again, pressing F8 again, but this time highlight 'start windows with last known good configuration' Doing any of these 2 things can be done in any order, either last known good config first or safe mode.
Oct 21, 2006 | Compaq Presario 2140US Notebook
HP Compaq Presario V2000 Notebook Logo
174 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
