Question about Kitchen Ranges
I have a Frigidaire self cleaning electric oven. I heard a two pops and this tripped the circuit breaker. I can't reset the circuit breaker because the pops occur again and trip the breaker again. Any thoughts? Rob from Toronto
I have the same problem. It's happen two times. The first time, it was an unprotected power lug connected to a heating element that makes contact with the metal cover (just under the glass). The breaker tripped and after a careful isolation maintenance it was ok. Last night another f*** spark occurred. This time, the breaker did not trip and the heating element’s warm light are always ON. It’s the same problem on a different position. But it was a thermostatic contact lug shorting whit the f*** metal cover. The main issue is that the glass top is used to maintain isolation gap between power lugs and the casing (grounded). In fact, heating elements are spring loaded to reduce the spacing between glass and elements. If a pressure is made by the counter-top the glass is forced to un-bond (my case) and elements can move, make short-circuit and burn down my house.
Regards,
Dave
Posted on Nov 10, 2009
    Problem Solver:
  • 7 Answers
Sounds like a shorted wire or something grounding.
Slide out range and unplug and take off bake and look around for a short either at the bake or broil element ot at the terminal where the cord connects.
Posted on Oct 01, 2009
Frigidaire oven
Sounds like your control board/panel has shorted out. You would definitely need a professional to diagnose correctly and properly repair.
Dec 26, 2012 | Frigidaire 30 in. Electric Gallery Pro...
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
During self-cleaning cycle we heard a loud pop and it tripped the breaker. Oven and stovetop (ceremic) still work but we smell the same smell from that cleaning cycle like electrical burning? Is there any...
If any appliance trippes the breaker there is a problem that has to be looked into, no appliance should trip MCBs or RCBs (trips), ISOLATE THE MAINS POWER BEFORE REMOVING ANY PANELS
A visual inspection of the rear is required, also the electrical mains connections. Look into this do not use the appliance until you have resolved the problem, it may turn out an amount of food had been stuck beside one of the heating elements, and causing a smell, better to be safe.
Let me know if you require any further assistance.
John
May 20, 2011 | Frigidaire Ovens
Frigidaire Gallery Series Electric Oven has stopped working. I was trying to preheat the oven and after a few minutes heard a very loud pop/bang. The oven had the PF (power failure) symbol flashing and my...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
Electric Dbl Wall Oven-loud popping noise at end of self clean
Bill ,i dont suspect the control unit is the problem im going back to the loud pop you heard I would say the pop you heard was one of the elemants blowing and that the reason the the breaker tripped if you say the clock,timer and light functon are ok it more so points to an elemant in most cases when an elemant blows it breaks the circuit .but the other componants also work when you reset the breaker i think in this case bill i would call a electrician it needs testing,sorry i could not help this time bill,but do not hesatate to contact me if i can help you again.adrian
Feb 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Kitchen Ranges Logo
234 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
