Hp 4100 inkjet printer not recognizing paper in tray
Hp 4100 inkjet printer. It doesn't recognise that the paper is loaded in the tray and prompts to load one every time and press enter to start print. Even when the enter key is pressed it comes back to prompting to load paper. Any clues what this could be? software issues or something to do with the printer itself..?
    President:
  • 787 Answers
Probably it's mechanical problem.This printers have more problems from this type.
Posted on Oct 01, 2009
    President:
  • 1,653 Answers
This is cased by a dirty paper feed path or paper feed sensor so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the sensors are all clean that the internal paper guides are all in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not worn or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Also check the paper pick up for wear as this will cause additional pages to be collected and fed through the printer. Make sure that you fan the paper before use ant it is of suitable quality and weight.
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Configure HP 4050 printer to prompt 'load paper'
You'll have to change the paper TYPE of tray 3 to a different type as in tray 2.
Jul 28, 2010 | HP LaserJet 4050 Printer
HP 7150 inkjet printer stopped loading paper.
Hello
Happy new year and start reading solution with Smile and trust.
Based on information you have provided I understand that your printer has stopped loading the Paper.I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
Please check the Following Link to get the guidelines
"How to Load Paper" its silly to ask you but its better to keep information updated
Try by Following the steps below to correct the issue:
  1. Disconnect power to the printer.
  2. Remove all photo paper from the Photo Tray.
  3. Push the Photo Tray completely into the printer.
  4. Snap the Photo Tray out (towards you) sharply.
  5. Reconnect power to the printer.
  6. Print a self-test on 8.5 X 10 paper.
  7. Engage the Photo Tray.
  8. From the Printer Toolbox, select Calibrate the Photo Tray.
If the above solution wont work then there something to do with the Adjustment/alignment of the Tray.
Paper is not picked due to the Try --
If you see inside there will be a small rubber which need to be clean by the spirit .. Check this out as well .. as i tried on my printer and it works
Do slow and with care --
If it works Vote me
Cheers
Tejodhar Atreya
Jan 04, 2010 | HP PhotoSmart 7150 InkJet Printer
HP Deskjet 690C says it is out of paper when it isn't.
Pretty well all printers come with two places to load paper: one paper tray and one feed tray.
Is the button on your computer or the setting in your word processor teling it to load from the other tray?
Sep 25, 2009 | HP DeskJet 690c InkJet Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
HP a612 paper loading
u will just have to place a paper in a paper feeding tray.thats in the lower base.maximum you can load is 50 -- 100 papers.minimum is 1 --paper in the tray.
Dec 18, 2008 | HP Photosmart A612 InkJet Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
663 people viewed this question
jasbo
jasbo
