Question about Microsoft Windows XP Home Edition
Mouse left button click is highlighting several programs at once. Mouse assumed to be faulty and replaced, but problem persists
  • keith_moo952 Oct 02, 2009
    Thank you for your suggestion however, I implemented a previous suggestion and the problem has been rectified.
  • 329 Answers
Try using USB mouse........
Posted on Oct 01, 2009
  • 662 Answers
It seems that you have activated click lock. The best way to resolve it is you restore your computer
Restart the computer in safe mode
Log in as administrator
Restore the computer to a date when it was working fine
reboot in normal mode
this should resolve your issue
Testimonial: "This suggested fix rectified the problem, so thank you very much."
  • 25 Answers
If you have got license version of windows XP home edition that u should download Microsoft Defender from the micrsoft's website and install it beacuse it might be that your xp is having malwares as u said u have replaced your mouse couple of times.
and in case if you are not using license version than change your default left click option with the right click steps are given bellow
1. open control pannel
2. double click on mouse icon
3. under the button configuration select the check box
4. now check will you get the same problem or not.
Posted on Oct 22, 2009
How to copy and paste
left click once on what you want to copy one item
hold down the left mouse button and move the mouse over the desired text you wish to select to copy and then let go of the left mouse button
so it is highlighted and then
hold down CTRL key and press C to copy
Hold down CTRL key and press V to Paste
Assuming it is a windows system
If it is apple the apple key and C I think does copy
Any edit tab option on the program usually has copy and paste
You can also use in Windows the right mouse button to bring up a menu where copy and paste are options to select.
If you are copying files you can also use CTRL A for select All
CTRL to select more than one item
Shift to select a range of items
if Windows
If you are using ubuntu the shift key plus CTRL plus V must also be used when pasting into the terminal window.
Aug 03, 2014 | Computers & Internet
How do you copy paste
I just select the part I need and move it from the internet to an open document on the desktop, since I run Linux Mint I had to learn how to do this to get my Terminal command correct
Nov 22, 2013 | Computers & Internet
How do i delete in wordpad?
Highlight the text you want to delete by holding down the left mouse button and dragging the mouse pointer over the text, then let go of the left mouse button.
Now you can just push the DELETE button or the BACKSPACE button on your keyboard.
Or you can use your mouse to place the mouse pointer on that section of highlighted text and then click the RIGHT mouse button once. Then select CUT from the drop down menu options. This will delete that section of text.
Good luck.
Apr 16, 2011 | ASUS Eee PC 1000HE Netbook
My coffee button disappeared off my menu screen. How do I restore the button? Where do I go...inventory maintenance screen? Thank you.
If you're referring to your desktop
Right mouse click on start
Left click explore
Find Program Files
Find your coffee program
Right mouse click on your executable file
Left mouse click on copy
Left mouse click on your desktop
Right mouse click your desktop
Left mouse click on Create shortcut
Done
Rick
May 07, 2010 | Pc America Restaurant Pro Express
I am a relatively new pc user. I get some emails and sometimes they want you to click on the linkbut I am unable. Then they will instruct you to copy and paste This where I need some help
I could be more specific if I knew what you were using for email but here goes.
Hold your mouse over the beginning of the link. Press the left mouse button and hold it down, now drag it to the end of the link. The link should now be highlighted, click on the right mouse button and a menu will pop up, select Copy.
Open a new browser window and in the address bar (where it shows http:// ....) click on it once with the left button, the address should highlight. Click on your right mouse button and select Paste.
Press the Enter key and you should go to that link.
Oct 14, 2008 | Computers & Internet
I need to set day and date display on my computer
I assume you mean date/time right click with the mouse on the time at bottom right hand corner a list will appear left click with mouse on adjust date\time a screen will appear and you can adjust time and date on that screen.
Another way to access this control is left click start button highlight control panel double left click with mouse and double left click on date/time option
Apr 27, 2008 | Computers & Internet
How to delete multiple things off my acer laptop at the same time
A good place to start is...
Start>Run>Control Panel>Add/Remove Programs
You can uninstall lots of programs here.
If you are trying to delete, lets say a bunch of files at once, here are some useful shortcuts.
Ctrl+Click will highlight everything you click on then you can hit delete once.
Click one item then Hold Shift+Click to select all files inbetween your first and last click.
Drag a box with the left mouse button to highlight multiple icons/files then hit delete.
Apr 23, 2008 | Computers & Internet
Mouse has lost its grip! (electrical grip, that is)
ok. i see your having great time using that mouse and you cared that device for several years. Try open your mouse and carefully remove these buttons of your mouse to clean those dirty stuff stacked on those linings( I believe that you haven't done this before, right?). I believe that this will need to clean a bit to give it back on track again.
Feb 23, 2008 | Logitech Cordless Mouse
Dual hard drive on laptop
create a folder on the d:\ drive and call it music and then move the music files on the c:\ to d:\music
Jan 28, 2008 | HP Pavilion dv8000t Notebook
Microsoft Windows XP Home Edition Logo
125 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
