Question about ViceVersa EM6060 Espresso Machine
Power light comes on but does not heat up - ViceVersa EM6060 Espresso Machine
  • 31 Answers
This is most likely a faulty thermal switch but could also be a fauly element.
Posted on Oct 01, 2009
Testimonial: "thanks for that, sounds like major drama if I cant get spares."
  • hjc100 Dec 13, 2010
    I have exactly the same problem. the two lower lights did come on at first (the lowest one flickered constantly) and when I pressed the central one it made a lot of noise but no water/coffee. It then stopped altogether with only the top light showing (it got very hot and i suspect this was a problem)
    I lifted the top off to find a rubber transparent hose had split and let moisture into the works and although it has dried it still does nothing-just the top light no heat or other activity.
    If it is a thermal fuse is it a straightforward enough job to repair? It doesn't merit a repair bill!
Light on switch is on no fan or heat
One phase of your power is missing. Lights work on 110v . Heat requires 220v . Measure voltages where the power comes in. You should have 3 wires coming in. Measure 110 across center and one side . Measure 110 across middle and opposite side. Measure 220 across 2 outside wires.
Oct 13, 2016 | Ovens
Ultima65 laminator wont heat
I would look for a fuse first, then it might be a heater problem
Jan 22, 2015 | Light Office Equipment & Supplies
If the dryer inside light comes on can the thermal fuse ok
No relations at all......
Light comes on means there is power and your door is open.
Thermal fuse failure means there is no heat. No current going through your heating circuit. Most models and brands will still turn the drum without heat. But there are some models thermal fuse will completely shut the power to heating circuit and drum motor. Like KENMORE certain dryers made by Whirlpool corporation
Jul 22, 2014 | GE GTDP180EDWW Electric Dryers
2001 lsv8 driver seat not heating switch light comes on just no heat
Power to the heating element has to be verified. Are you familiar with a test light? If power is present then heating wires built in to seat are broken. This can be checked with an ohm meter. Good luck!
Mar 15, 2010 | 2001 Lincoln LS
My francis francis x3 does not heat the water, I have a power light on, but no heat?
Does the bottom light come on? The light is connected across the heating element and so if it is on the heating element is getting power. From looking at mine it looks like the bottom button for steam power bypasses the thermostat and uses the pressure switch to shut off the heating element. So if the light comes on when you press the steam switch but off when it isn't it is most likely your thermostat causing problems, if it never lights it is most likely the pressure switch. I do not claim to be an expert on the machine but from looking at mine that is what i would expect.
Jan 13, 2010 | FrancisFrancis! X3 Espresso Machine
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Heater seats dont work but light comes on.
Ok it is obvious since the light is coming on you are getting power to the switch. It could be a heated seat relay. Im fairly sure jeeps use a relay after the switch that is where I would start. Check and see if the Heated seat relay, and fuse are good
Dec 11, 2008 | 2001 Jeep Grand Cherokee
ViceVersa EM6060 Espresso Machine Logo
120 people viewed this question
Top ViceVersa Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a ViceVersa Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
