Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Freeview is not working on my samsung tv normal tv is ok freeview not working since 30-09-09
Freeviw not working on my Samsung LA40A750D but did work through a free view box on another tv previously
Posted on Dec 20, 2010
I cant make the freeview box work without the operating instructions
OK - please follow these instructions carefully to setup the Freeview box. If you get stuck at any point in the instructions - or anything I've said doesn't make sense or match what you can see - just post another message here and I'll deal with each problem as it arises.
1. Switch the TV and Freeview box to STANDBY. There should be a red light on the Freeview box;
2. Connect the aerial cable to the freeview box. Make sure you are connecting this to the correct socket. This should be labelled "RF IN", "IN" or "Aerial/Antenna". If you have connected to a socket marked "RF/TV OUT" or "TO TV" or something similar, it wont work;
3. Connect the SCART cable to Freeview box and the back of the TV;
4. Switch the TV on;
5. Switch the Freeview box on - you should get a green light on the front of the box;
Most TVs will automatically switch to the external input when a SCART device is switched on while the TV is already on. This is why you should switch the TV on first.
At this point you should be able to see the installation / setup screen for the Freeview box displayed on your TV. If you cannot see this:
A. Press the INPUT button once on your SAMSUNG remote control once. This is the button in the top-right corner of your remote control.
B. If you still cannot see the installation / setup screen, press the MENU or SETUP button on the remote control supplied with the Freeview box.
The instructions from this point forward will be different if you had to press the MENU / SETUP button on the Freeview remote before anything appeared on the TV screen. If this Freeview box has been used before the installation screen will not appear, but you will get at on-screen menu after pressing the MENU / SETUP button. If this happens, please let me know and I will provide alternative instructions for setup.
Assuming you have been able to access the installation screen, it should be easy enough to follow the instructions on screen from this point. Use the UP / DOWN / LEFT / RIGHT arrow keys on the Freeview remote to highlight the relevant options and then press OK / SELECT to choose that option.
I don't want to make this too complicated by providing alternative instructions for every possible scenario. Please run through the instructions above and make sure you are getting an installation screen or "menu/list" displayed on the TV. If you need further instructions from there, I will provide them in another message.
Good luck - I'll await your reply.
Regards,
BElectric
Feb 09, 2011 | Televison & Video
Samsung LE32N7 - Analogue channels ok - Freeview set top box ok- Tv's own digital tuner stuck on one channel (BBC1) in freeze mode - and won't unfreeze. Cannot access DTV menu- does not reset on power...
This is very common to a number of Samsung models built at the same time as yours and using the same in-built Freeview receiver.
There is no fix, the built in receiver is simply incompatible with the most recent updates to Freeview (as happened to many external boxes) and cannot be modified, the only puzzle is the length of time that your receiver kept going for. If your tv has a warranty still then you may wish to see if the fault is covered.
Without a warranty, all you can do is continue to use an external Freeview receiver. They're usually better quality anyway, and are easy to replace when they go wrong or become out of date.
Sep 17, 2010 | Samsung Televison & Video
New capacitors now freeview unavailable
what was the need to replace capacitors. if so on which circuit? Hope you have replaced the right value and type of the capacitor. Observe whether soldered points getting into other pcb track. Clean them again and give a try.
Jul 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
My TV has built in Freeview but I can't get it to work
Ah...that model has the usual Samsung remote and instruction booklet: both are poorly designed. it's a shame as the TV itself is OK.
To select between digital and analogue channels you use the "source" button to cycle between all sources; there's one button on the TV and another on the remote (from memory it's in the centre of the upper half of the remote, but will be clearly shown in the user booklet).
Nov 01, 2009 | Televison & Video
I have the same problem - please help as no Cebbies!
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Oct 01, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Up until today samsung freeview tv model LE26R74Bd working fine: this am, will not do anything except volume control, stuck on BBC2, have tried new batteries in remote, leaving off for an hour. Buttons on...
PRESS THE DTV / TV BUTTON TO GET TO THE MENU.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Samsung LE26R72B 26 in. HD-Ready LCD...
No sound when watching freeview on Samsung 32" LCD TV
I`ve got the same problem, sound with analog but not digital?
Dec 12, 2007 | Televison & Video
Built in freeview locked up in tv
I also got a black screen! I then turned the TV off, pressed TV and while it was lit, quickly pressed info, menu and then mute. Then switched the tv back on and amazingly......the menu was there. Go to item 12 and reset. I am please to say that we are back in business,
Jul 12, 2007 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
751 people viewed this question
Henry  Thomas
Henry Thomas
