Question about Dell 1320c Laser Printer
My dell 1320c only prints first3 pages of a pdf then the load paper tray light comes on. If you open and close the drawer it goes back and prints first 3 pages again... any ideas? The printer is networked and I'm using vista
I had this problem with open office text files - the solution was to change the Page format (go to Format>Page) and set the page format to A4.
Posted on Jan 27, 2010
Ok this is what fixed it for me:
go to the printer utility:
Control Panel\Hardware and Sound\Devices and Printers\Dell Color Laser 1320c
Click " Adjust Print" options
Dell 1320C Printing Preferences window opens
Click "Advanced"
Change " overwrite paper source setting in application" from off to on
presto its fixed
Posted on May 09, 2013
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Continues to print same page over and over
Remove paper from paper tray.
Do the following to clear print que:
Control panel.
Printers and Faxes.
Select your printer and click "See what's printing" on the left of your screen.
Click Printer tab and select "Cancel all documents".
That should do it.
Take care!
damnor01
Jun 06, 2012 | Dell 1320c Laser Printer
Code c0910
This error code means there is a paper lifting problem in the paper trays. Most common cause is improperly loaded paper. Check the trays to be sure all paper is loaded properly then turn off then back on, the MAIN power switch Not the one up on the control panel. If the code does not come back then your fine. If it does then pull out all of the paper drawers, reset the code again and then close each drawer one at a time waiting 15 seconds between each tray closing. If you close a drawer and it pops the code after a few seconds then that is the tray that is causing the problem. Double check that tray and if you can not get it to work then you will need service on that tray as it has a paper lift problem. Either the lift motor or the sensor. You can leave that tray popped open an inch or two and still use the copier with the other trays.
Good Luck and Thank You using Fixya.
Sep 22, 2010 | NEC IT2520 Fax
How to clear flashing exclamation error light
taker out the toner/cartridge, the paper and then unplug the power.. Also open the printer cover and look for any paper which could be jammed.. take out the paper as well ..
Ensure that all the papers are properly stacked in each tray.
Also fan out the paper before loading in the printer.
After about 10 seconds, plug the power back in and reinsert the ink/toner and paper.
Sep 07, 2010 | Dell 1320c Laser Printer
Wrong size paper error Dell 1320C
if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
Dec 20, 2009 | Dell 1320c Laser Printer
Dell colour laser 1320c printer prints one page
in your printer properties set the paper size according to your printer paper size.
Nov 27, 2009 | Dell 1320c Laser Printer
Dell 1320C
On page 30 of the 1320c manual it says this signifies the coming end of the PHD (print head device). I cannot find a part number or reference to the PHD on the Dell web site pages connected with this printer
Jan 30, 2009 | Dell 1320c Laser Printer
Dell 1320c printing error "no paper detected"
I had the same problem. I removed the paper tray, turned the printer on its side and manually moved all the working parts on the bottom of the printer - rollers and switches..
When I reinserted the paper tray, everything worked fine.
PS. I ordered and returned a new paper tray from Dell, that was not the problem.
Jan 09, 2009 | Dell 1320c Laser Printer
Dell printer 3100 cn laser
I had the dreaded 024-969 and was just able to print a test page.
I removed paper and reached inside the MPF. There's a spring-loaded lever facing upward, toward the back of the tray that the paper rests on and depresses. I toggled this up and down a dozen times.
I vacuumed out the entire tray area and then blew air into the same area by reversing the shop vac hose connection to the output hole.
Printer now prints.
Jun 11, 2008 | Dell 3100cn Laser Printer
Dell 1320c Laser Printer Logo
922 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
