Question about Canon S400 InkJet Printer
Printer not working. The light flashes red six times.
Printer carriage is in the position for replacing ink cartridges.
We are only printing in black. There is black ink, but one of the colour cartridges is [nearly] empty.
    President:
  • 787 Answers
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Posted on Oct 01, 2009
komguy
  • 2306 Answers
SOURCE: black ink will not print. Colours ok
Neither solution will help, Brother has had some bad printheads and the only repair is to install a new printhead. It's a shop repair and runs around $170.00. Under warranty there's no charge. The thing you really don't want to do is blow air into the system as it takes another full ink to get the air bubbles out. Sorry for the Stupid help above.
Posted on Feb 09, 2010
khanmohammad
  • 188 Answers
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Posted on Mar 25, 2008
yooperbud
  • 8637 Answers
SOURCE: Epson RX420 new black ink cartridges displaying empty
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
  • 6 Answers
SOURCE: Brother MC420CN- Black ink cartidge 'near empty' message persists
At 1 of the end sides of the cartage you will see a little window, a beam of light hits that window to determine if you need Ink..Place a small piece of Electric tape over that window and.wallah print,fax and copy away. Brother is a ripoff-A cheap printer that auto-cleans(wastes ink) and locks the whole system claiming your out of Ink or low>>>But this is sure to work! ;)
Posted on Dec 17, 2009
  • 973 Answers
SOURCE: I have replaced all the ink cartridges, but it
Try unplugging the printer, waiting a few minutes and replugging it back in.
Posted on May 29, 2010
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
Epson R2400 paper and ink lights blinking red. Ink waste pad replaced and counter reset to 0. Lights still blinking red. Close inspection for any loose objects in printer but none found. Please advise....
Try to turn on your printer without the ink cartridges. When the printer starts and ask for the cartridges, put them back in.
(To remove the cartridges turn on the printer, watch the print head carriage move, when it is at the center quickly unplug the power cable, move the carriage by hand to a position where you can remove the cartridges, after removing the cartridges push the carriage to the right where it should be parked.)
Sep 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
I changed the ink cartridges and i can not get the
Do you mean you can't print text in black? You are correct to replace black ink. Turn off printer. Turn on printer, and immediately unplug power when carriage moving. So, carriage will stop not at parking position. Unplug usb. Move carriage freely bay hand.
Aug 12, 2009 | Epson Office Equipment & Supplies
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Carriage hits the right inside of printer - will not print
if the lights are flashing along together there is a cariage stall. The ink cartridge craddle is hitting something. Find out what and remove it if doesn't belong there. First of all remove and reinsert both cartridges. One of them may be inserted wrong.
Mar 19, 2008 | Office Equipment & Supplies
Canon S400 InkJet Printer Logo
1,486 people viewed this question
old marine
old marine
