Hotpoint aquarius leaking
Hotpoint aquarius wt 965 leaking at drawer
    Genius:
  • Washing Mach... Master
  • 1,467 Answers
If this is leaking as its filling check its clean and nothing in it you can also remove drawer, check dispeser hose...good luck
Posted on Oct 01, 2009
Water is spilling out from d soap drawer and door area when washing machine is switched on.Its a hotpoint aquarius WT 740
if its a front loader, u have something stuck in the drawer hose inside. like a sock or clothing item
Feb 12, 2010 | Washing Machines
How do I remove the drawer from my Hotpoint aquarius WMF 540 to clean it??? x
Open the drawer, lift or push it upwards, and pull it out towards you.
You should now be able to clean it.
Please rate my solution.
Thankyou.
Jan 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
At 20 minutes the drawer leaks
have you removed the drawer and cleaned the soap drawer holder ? as these can be blocked and cause this fault
Sep 15, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarius wd62 front drawer leaks
I had this problem and solved it by just leaving the draw sticking out a little bit! Now there are no leaks!
Feb 01, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Water is leaking from soap dispenser only at beginning of cycle
Remove dispenser drawer, and check for soap blockage.
Locate and clean filter, check to see if there is one located behind bottom kick strip, if no filter there, then you will have to remove lower rear cover of washer, and locate and remove the large black hose on bottom of tub.
Remove filter and plastic ball,clean and replace.
Refit filter, ball and hose ,ensuring it is fitted correctly.
Test for leaks.
Plz ratev my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Water leaking (Aquarius 1200)
don't think using quick wash should make a difference as water intake is the same take drawer out and wash thoroughly especially the rinse compartment. if gunged up the water overflows the compartment and leaks down the front. otherwise, you may have a blockage in the hose from the drawer to the tub. take top off, remove this hose and clean disconnect from mains when you do this
Apr 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
