Question about Dell Dimension 3100 PC Desktop
No sounds of any kind
I replaced my cd-rom drive with a memorex cd-rw burner. I wasnt able to hear any sounds from the cd, so I removed it & put the original back in, making no changes. Now I have no sound whatsoever, such as the windows welcome chords or any other sounds. All troubleshooting says all devices are working properly. I'm at a loss -- Thanx, Rick
  • 2 more comments
  • sprint100 Dec 20, 2007
    the 4-pin analog audio jack was not used with my original drive, the new drive came with a 4-pin cable, but theres no visible sound card to plug it into. the jumper is set to cable select, which is where it was originally
    I went through all the troubleshooting screens & it said my drivers were digitally signed, they were the right ones, they were working correctly, etc. The speakers were both working fine up until I switched the cd drive, I dont think they just failed coincidentally.
    Yes, I made sure the volume was up, & no mute boxes were checked, how do I check the BIOS ?
    I checked bios settings, all audio is enabled, I was wondering since my sound card is integrated, I have no place to plug the analog audio connector from the cd drive. If I added a sound card & hooked up the cable to it, would that help? According to that flow chart, If there's no analog audio cable hooked up, (which there was not originally) I wont be able to play audio cd's at all
    President:
  • 1,944 Answers
Did you connect the audio pins of the cdrom when you installed it? It's on the back and should be labelled.
Posted on Dec 20, 2007
  • 5 more comments
  • Damen Wong
    Damen Wong Dec 20, 2007
    I mean the 4 pin cable
  • Damen Wong
  • Damen Wong
    I see...did you rule out drivers/bad speakers as the source of the problem?
  • Damen Wong
    I assume that you checked that the sound hasn't been muted by Windows? Did you check in your BIOS to see that maybe there is some sound setting that disables sounds or your sound card?
  • Damen Wong
    When you turn on your computer...look quickly and see what keys need to be pressed to access the BIOS (it's different with each manufacturer so I can't tell you exaclt what to press...it could be F1 or F2 or ctrl+alt+esc). Is Digital Audio on the Drive enable or disabled?
  • Damen Wong
    Here is a nice troubleshooting flow chart
  • Damen Wong
    Adding a sound card and then using the 4 pin cable would work.
I have this cd-r by memorex that already has downloaded songs but i want to erase them and put new ones ...please explain how to do this...
You cant.
A CD-R (Compact Disc-Recordable) is a variation of the Compact Disc invented by Philips and Sony. CD-R is a Write Once Read Many (WORM) optical medium, though the whole disk does not have to be entirely written in the same session.
CD-R retains a high level of compatibility with standard CD readers, unlike CD-RW - which can be re-written, but is not capable of playing on many readers, and also uses more expensive media..
If you want to be able to use the disc many times, you need to buy CD-RW discs
Aug 05, 2010 | Memorex (32023244) CD-RW/DVD-ROM Combo...
How do I format a CD-RW disc? Are there cetain CD-RW discs for 64-bit OS only?
Hi! You may click on start - computer and then click on the dvd drive where the CD- RW disc is located and then right click on it then choose format. CD - RW discs are compatible for both 32-64 bit os. Thank you for visiting FixYa.com!
Jun 04, 2010 | Memorex (32023244) CD-RW/DVD-ROM Combo...
How to delete content on cd-r from windows vista 64-bit
Hi and thank you for using fixya.
First of all you can only delete content when you have a CD-RW unit on your pc. Also the CD that you would like to delete has to be CD-RW as well. If all of the above apply follow this instructions:
1- you will put the CD in your computer. 2- go to my computer 3- open the D: drive 4- select all content 5- press the delete on your keyboard or right click delete
Hope it works
Good luck
Mar 14, 2010 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Brand new one won't open
try to put needle to small hole on front face of drive, but I recommend you to take warranty and get new drive, sometimes you buy faulty new things, that is normal, when almost every hardware is made in China...
Jul 10, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Help with copying cds keeps saying that I have wrong format
the machine (pc or cd burner) that you are using is looking for a specific type (either cd-r / cd+r)
look on the front of the pc or cd burner to find what type it uses.
cd + r, cd + rw, cd - r, cd - rw or cd-rom. (+/-) r are for one time burning, (+/-) rw is for rewriting over and over and the rom is for games (playstation).......the + (plus) or - (minus) is very important.
feel free to rate if this is helpful
Jun 07, 2009 | Memorex CD 482E (CD-482E) CD-ROM Drive
Acts like a Player/CD burner
I have an IDE Memorex DVD±RW Dual Layer Burner (52x32x16) that has burned well over 300 cd/dvd' sense 2004 when I bought it. In 2006 or 7, an update was given to it via memorex sight - I was told to keep a copy of the dn ld, for it can't be undone and became "IDE Memorex DVD±RW Dual Layer Burner (523216)AJ___NWK____\5&265FB54&0&000" MODEL - I got it on sale from Fry's Elec. - It seems that it was indeed a 1 way ticket - and it is time to retire the old work horse anyway - Quite happy with your products and getting me another. PS - I don't think the upgrade did any justus
May 04, 2009 | Computers & Internet
No audio on toshiba sat pro
MAY BE THE ONE YOU TRANSFER THE HARDWARES TO DOES NOT HAVE SOUND DRIVER YOU NEED TO LOAD SOUND CARD DRIVER ON IT BEFOR YOU CAN HEAR SOUND.check the below site and see if it can solve the problem
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-Pro-6100/download/page,sh,31303,221,19,.html
Dec 24, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
DVD ROM CANT READ DISC
Please go and buy a new dvd writer in place of dvd-rom.
Dec 05, 2007 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Memorex cd-rw/dvd-rom wont install
FOrget the cd in the box.
http://memorex.com/html/download_software.php?sid=15
Download the latest driver for the product, and matching your computer and operating system.
Oct 22, 2007 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Dell Dimension 3100 PC Desktop Logo
43 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
