Question about Lexmark T632 Laser Printer
Printer start to print on A5 paper at full speed, after 20 copies printer stops and after 30 seconds printer starts again at half speed. Why? We need the full speed for the complete batch.
CoachTim
  • 202 Answers
SOURCE: Lexmark X75 All In One printing problme
Have you run print head alignment? or To clean the cartridge carrier contacts on the printer, do the following: 1. Power off the printer and remove it from the mains supply. 2. Open the printer lid so that you have access to the cartridges. 3. Pull gently on the ribbon cable connected to the carrier until the carrier is accessible. 4. Remove the cartridges. 5. Using a dry, clean cloth, wipe the contacts of the carrier gently from top to bottom. 6. Repeat Step 5 on the second carrier slot (where applicable). 7. Reinsert the cartridges and close the lid. 8. Reconnect the printer to the mains supply and turn on the printer again. Let me know what happens. Good Luck, Tim
Posted on Mar 17, 2007
Printerguy
  • 31 Answers
SOURCE: paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Posted on Aug 27, 2007
SOURCE: lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Posted on Oct 26, 2008
  • 85 Answers
SOURCE: Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Posted on Feb 15, 2009
madguy1089
  • 21 Answers
SOURCE: When a page prints it only goes half ways and then stops and the printer says paper jam
Typically what I have seen with these printers if they do that it is because there is something blocking the path of the paper. What you can do if you are comfortable!!
Unplug the printer and lift the printer and and give it a good shake and what ever is blocking the paper will fall out if not it may loosen it enough so that when put the printer down and take a flash light and shine it down the paper feed area you will be able to see what is there and then pull it out with either a pair of needle noose pliers or your hands.
Also if you have a warranty on the printer you can just call Lexmark and they will either walk you through the same process or they will send you a new printer.
Posted on Jun 09, 2009
I'm using half of A4 size paper and when I print my file on it, it takes 20 seconds after feeding the paper. Is there anything I can do to make it faster?
I fixed your capitalisation, punctuation and grammar. Half of an A4 sheet is an A5 sheet and should take half as long to print an A4 sheet. Print speed is dependent on a number of variables;
Density of colour, the more colour or more blocks of black take longer. Yours is monochrome and these are the specs. You should get 12 pages per minute. It may be that your computer is slow and also is low on available RAM memory. This is an old printer and you may think about upgrading. I had one of these 10 years ago.
Benefits
  • 12 ppm mono printing
  • Zero warm-up time from sleep mode
  • First Print Out Time in only 9.3 seconds
  • Up to 2400 x 600dpi print resolution
  • Energy efficient and quiet operation
  • Easy to use All-in-One cartridge
You should get 12 pages per minutes
Sep 16, 2015 | Canon LASER SHOT LBP-2900 Printer
Printer stops printing, blinks
maybe have a look in the settings and change the priority setting to right now or urgent or something like that
Mar 28, 2012 | Okidata 591 Printer
I was printing and everything was fine. Now, I hit start to copy an item, printer waits about 30 seconds, and shoots out a blank paper. I know I was low on ink, so I replaced the cartridge. It prints the...
You printer probably needs to be reset. First, remove both cartridges from the printer. Unplug the power adapter from the back of your printer(small black box behind your printer where the power cord is attached)
(model shown may not be your printer, however, the steps are the same)
Wait for at 10 seconds before reinserting the power adapter back into the printer. When the printer turns on and looks for the cartridges, reinsert both cartridges. Let it print the test paper again. Then try to print your document again to check if it's working now.
Apr 04, 2011 | Lexmark X6150 All-In-One InkJet Printer
Dear Sirs, I have a DATAMAX I 4308 ,I am very satisfied with him. Sometimes when I print on low speed after 20 min.labels are printed discontinuosly I had on display MOTOR THROTTLING ,printer stopped...
Motor Throttling is a warning message designed to protect and prevent the power supply and motor from overheating. It occurs after 30 minutes or so of continuous printing and printing slows down to about half the speed. It will eventually go back to printing regular speed, but if it's that much of annoyance it can be disabled under the printer menu under print control. If you wish you can do that.
Jun 05, 2010 | Datamax I-4308 Thermal Label Printer
Samsung CLP-315W Color Laser Printer will print only half page
http://www.fixya.com/support/t3934542-exit_sensor_problem_samsung_clp_315
Mar 23, 2010 | Samsung CLP-315W Laser Color Printer
I have a 2100 HP Laser Jet Printer with no manual. After it prints one doc. it continues to feed 1 1/2 sheets of paper and stops. The paper is hung in the printer and I have to take out the paper so I can...
this might be a hardware problem please follow the steps
1.disconnect the power cable from the back of the printer
2.press and hold the power button for 20-30 seconds
3.reconnect the power cable back to the printer
follow the instruction from the below mentioned URL
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=25469&prodTypeId=18972&prodSeriesId=25469&objectID=bpl06448
and if still its the same problem try and make a copy if the copy is not fine its surely a hardware problem contact HP if the printer is in warranty
hp toll free number -1800-474-6836.
hope your issue gets resolved
thank you
Hamid
Feb 19, 2010 | HP LaserJet 2100 Printer
We produce a small magazine of 20 pages (A5) using open office writer. The problem is that when we print 200 copies on the Kyocera 3035 it seems to send each copy to the printer in sequence taking well...
for printing 4000 pages in a hour or hour-and-a-half, that is not bad. it could be better.
the changes in the open office not in the printer. Try to send the print job to the printer with spool on and uncheck the print the last page first.
Feb 26, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Paper trays
1. Remove the print driver on the PC if this is a local shared printer.
2. Re-share the printer will cause the driver to re-install.
Now the next way to fix issues like this too go to step 3, but only if step 1 and 2 does the same effect.
3. Turn it off and unplug it for 30 seconds.. Now plugin the power. Press and hold the power button for 30 seconds to force a reset back to factory defaults.
Still it sounds like a configuration error or bad network driver if this printer is on the network.
Jul 23, 2008 | Xerox Phaser 7700DN Laser Printer
Konica Minolta PagePro 1350W low print speed
Jacques,
Print speeds will vary based on a lot of factors. First thing to note is that your printer should have a first print time of about 20 seconds. This means the first page should take about 20 seconds before it starts printing and than will print at rated engine speed.
Secondly, depending on the type of paper and thickness your speed may slow down. Most printers will slow down for a thicker paper. In general the thicker the paper the more time it needs for the toner to fuse or melt to the paper.
The size of the paper will also greatly affect the speed too. Manufacturers spec their machines to letter size in the portrait orientation (the leading edge is the 11 inch or long side). In general for legal you will have a 15 to 20% reduction in speed and for 11 x 17 you can have as much as a 40% or more reduction in speed.
Print resolution may affect the speed. Usually most printers will print faster in a draft mode. This may also reduce the amount of toner used.
How do you connect to your printer? Different cables all have different speeds. For that matter is there an upgrade to the RAM? This could also change the speed of the print job. However these should not affect the final speed too much.
So to get the "rated" speed of your printer you will need to use standard letter paper with the long edge leading. Remember don't use thick paper and use a draft mode or lower resolution if possible to get the best speed.
I hope this helps.
Henry
Jun 02, 2008 | Konica Minolta PagePro 1350W Laser Printer
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
Lexmark T632 Laser Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
