DVD Players
Problem for DVD Players
Generic problem for all DVD Players
DVD shows ''UNKNOWN DISC'' and came out
By isejin on Oct 01, 2009
When I insert DVD disc this recorder try to read disc but few second later disc will come out. try ''setup'' but half of fuction not working. I used this machine only 3 times (warranty is over 6 month ago)
Please help me. Thank you (in advance)
Comments:
Oct 17, 2009
- I try Verbatim and even import Mitsubishi from Japan. It is still have same problem. Thank you 2 gents for help! But nachine is still,,,,,
Oct 19, 2009
- model is LG LRH-880 any blank DVD insert still came out with "unknown disc" sign showed. try with VERBATIM (its mitsubishi brand), still did not reading and came out but on display ther is no sign of "unknown disc" any help? PLEASE HELP~~~!
Oct 21, 2009
- Hi! I get LG GSA-H50N today and try to replace it. But back and bottom of new unit is different from origainal one. I have to stop there,,, I have no clue! Please HELP! PS, I try to contact LG Canada they are real rude!!! I like to buy some Parts, please transfer to parts dept. "go to www.lg.ca" I like to buy some prats! "just send machine to company. I am only switch board operator"!!! Could you switch to any tech guy? "they are all busy!!!" That's what LG Canada treat customer!!! I never buy LG in Canada!!!!!!!!!!!!!!!!!!
Oct 21, 2009
Oct 23, 2009
- I try send some photo to "kw7157@yahoo.com.uk" but keep came back.
Oct 27, 2009
- kw7157@yahoo.co.uk I try to send pictures for this e-mail, But somehow keep return it. Would you please good e-mail address?
Solution #1
posted on Oct 01, 2009
Not Helpful)
57 varieties
Rank: Guru
Rating: 88%, 542 votes
This is due to you trying to use the wrong type of DVD. refer to the manual for your system to see what ypes of disc it will accept. There are also many cheap DVD disks on the market that will not operate in vertain DVD systems. These are mainly cheap disks that have been made to a low quality standard. Also there are many systems that do not like certain manufacturers disks, typically Ricoh and others.
Comments:
Oct 18, 2009
- What is the mfr and model of the DVD Player? I can go through the service manual and mfr info to see if there are any specifics that will cause this problem in your machine.
Oct 19, 2009
- I think that given the problems with reading the different media that you have tried shows that the drive itself is the problem and needs replacing. This has occurred on several of the LG LRH recorders but there is a solution.
The only drive that seems to work and is recommended as a replacement drive is an LG GSA-H50N (that comes with a beige or black front) but no other 'N' type LG drives seem to work. These are high quality drives abnd are freely available from many online sources at around US $35, £25, E25
Oct 19, 2009
The only drive that seems to work and is recommended as a replacement drive is an LG GSA-H50N (that comes with a beige or black front) but no other 'N' type LG drives seem to work. These are high quality drives and are freely available from many online sources at around US $35, £25, E25. These can be swapped out really easily by unplugging the existing connectors and removing the mounting screws and simply placing the new drive in place of the old one, screwing back the mounting screws, reconnecting the connectors and powering back on the unit.
Oct 21, 2009
- If you would like to pursue this via email so you can send some pictures I can assist.
kw7157@yahoo.co.uk
Oct 27, 2009
The email address is kw7157@yahoo.co.uk
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
noobcybort
Rank: Wiz
Rating: 83%, 51 votes
Hi, does it happen to all DVD's  or only some ?  if it  plays others ie cd's  then your player can't play all formats or does not play fake cd's .
Get a technician  to check its mechanism (disk compartment ) even swap lens sometimes the lens has weaken .
good luck dude .
Was this helpful?
Yes
No
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
Which is the Best and Lower Price DVD player
Answer
player stopped during play mode,unable to control with remote or dvd control buttons.
Answer
hdmi cable gives me nothing into my new sony lcd digital color tv. cannot get home menu to display... (More)
Answer
Where can I download the firmware for the magnavox dp100mw8b?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
