Question about Olympus Camedia C-5060 Wide Zoom Digital Camera
How do i re-size photos i want to take in the camera menus? Philip
When i try to take photo it sayes card lock,help please
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card.
Jan 03, 2011 | BenQ DC C640 Digital Camera
Photos i have taken saved onto the internal memory of my panasonic lumix camera even though there is plenty of space on my sd card. when i pressed play it only showed the photos from the internal memory so...
This is a problem with the memory card. I don't know why your camera is not giving an error message of some kind- it seems to know that it can't store pictures there.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 05, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
How do you reduce the size of images already taken
There are three options
Print the photo in smaller size you want
Reduce the size of the photo with the camera settings
or upload the photo to the computer and save it as a jpeg picture with any photo editing programme.
Jan 19, 2010 | Canon EOS 400D Digital Camera
'Write project'
I don't know this message, and am going to guess what can be done. I searched on the Olympus site for such a message, none. Not sure what it means.
I believe this has to do with a setting in the menus.
Turn the camera on, go to the menus and set all to factory default, or something like that such as reset or reset all.
Test the camera after setting and set the menus to what you want.
Oct 27, 2009 | Olympus Stylus 820 Digital Camera
How do you make the date print on photos?
Most cameras have a setting in the menus to allow the date and time to print to the screen and photos on playback.
Look in the menus having to do with the date settings. Note that some settings will affect others, so it may be a good idea to look at your manual. In most of the Canons I have and have worked on, they all have the setting to put the date and time on the picture.
Aug 30, 2009 | Canon PowerShot SD790 IS Digital Camera
Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
Mar 11, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Deleting texts and photos
To delete messages:
>Messages
>Press Open Menus button (black round button in the middle of the 4 way selector arrows)
>Cleanup Messages
>Select
>All
>Select, etc
The Open Menus button is worth remembering because it open a lot of submenus that can't be accessed any other way.
To delete photos:
>Multimedia
>Pictures
>Additional Storage Device
>cursor onto photo
>Open Menus button
>Delete
Dec 27, 2008 | Motorola Mobility W377 Met Silver/Pink...
Why can't I access Shooting Menus?
The Shooting Menus allow the user to control many aspects of the operation of the digital camera. You can change image size and compression, exposure compensation, sharpening, etc. When using a "Scene Mode" (Fireworks, Museum, Beach/Snow, etc)the camera determines the best settings for the particular scene and the options are limited in the Shooting Menus. If the Shooting Menu contains fewer options than expected or you are unable to adjust a particular setting be sure that the camera is not set in a scene mode. Depending on the camera model you should use "A" or "M" mode for full control.
Aug 30, 2005 | Nikon Coolpix 3500 Digital Camera
Aug 30, 2005 | Nikon Coolpix 2500 Digital Camera
Olympus Camedia C-5060 Wide Zoom Digital Camera Logo
13 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
