Question about Black & Decker D2030 Iron
Will this iron work on 240 volts in th UK ? Peter Lee
    President:
  • 1,653 Answers
As long as it is rated at 230- 250VAC then it will work in the UK.
Posted on Oct 01, 2009
Testimonial: "Thanks , but can the 230 / 240 volt one be bought in USA ? We cannot find one in the UK , Peter Lee"
How many voltage pass through the thermal fuse in the black&decker iron
240 volts
cheap to buy a replacement than fiddle with faulty iron
Sep 26, 2016 | Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
Jun 23, 2015 | Oliso TG-1000 Iron
Can an appliance with a nema 6-20p plug be used in the uk?
It will probably require an adapter. If the equipment you're trying to power is dependent upon 60Hz power, it may not work correctly on the 50Hz power found in the UK... especially if it has an electric motor.
Aug 11, 2014 | Miele Rotary B890 Iron
5 amps is how many watts?
Depends on the input voltage. Using the P= I x E (P)ower (watts) = (I) Current (amps) times (E) Voltage (volts)) rule, at 120VAC it would be 600 Watts. At 240 VAC it is 1200 Watts.
Aug 04, 2014 | Irons
I love my iron ! How I can use in Israel?
The voltage in Israel is 220 volts. Check the information plate on your iron to see if it will operate on 220 volts. If it will, then you will only need an adapter from the two round pins to a two slot receptacle that you can plug your iron into. If your iron will not use 220 volts then you will need a 220/120 volt transformer with a 1 and one half times larger wattage rating on it than watt rating on your iron. Our iron is 1200 watts. We would need a 2000 watt transformer. On Amazon they cost eighty nine dollars and weigh 29 pounds. And they ship them overseas. Best of Luck
Nov 02, 2013 | Euro-Pro Irons
I need a manual for swan steam generator iron item si4030n
http://www.swan-brand.co.uk/swan-2200w-steam-generator-iron-1.html see Documentation http://www.swan-brand.co.uk/media/swan/ib/SI4030N.pdf
Jun 15, 2012 | Irons
If using with a power strip or extension cord, how many amps does the iron pull -- it is 1700 watt the kind I have
Power = Current x Emf
Current = Power / Emf
Current - Amps
Emf - Volts
Power - Watts
Current = 1700 watts / 120 Volts = 14 Amps
If you live in Europe then -
Current = 1700 watts / 240 Volts = 7 Amps
Be sure your breaker and extension cord are rated for the amperage.
Nov 19, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Shark euro pro x
We fixed ours today. Take the iron plate off (bottom of the iron shaped like a triangle). You are looking for a thermal fuse (or thermal-protector fuse) pictured here for less than $2 at Radio Shack(http://www.radioshack.com/product/index.jsp?productId=2102788&CAWELAID=107599331). You will need needlenose pliers to gently remove the old fuse and the wire cutters to trim the long wires to the same length as the old fuse (less than 1/2"). Also, since the old fuse was 240 C and we only could find a 228 C replacement - we cannot use the iron at the same high temp. So we limited the dial by marking out a portion of the dial. The iron stopped working after I kept the iron on high for an extended period of time. My electrician husband explained that I over heated the iron - breaking the fuse. Not time I'll turn the iron off or down when I'm not using it. This was so easy, I'm going to check out our other broken irons.
Jul 05, 2008 | Euro-Pro Shark GI490 Iron
Black & Decker D2030 Iron Logo
247 people viewed this question
Top Black & Decker Irons Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
Are you a Black & Decker Iron Expert? Answer questions, earn points and help others
