Question about MSI P31 Neo-F Core 2 Quad Socket 775 1333MHz PC2-6400 ATX Motherboard Retail
How do you overclock a MSI P45 NEO-F? The bios menu is strange and it doesn't allow me to change the FSB settings. PLZ help me!!!
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
aaa17
Posted on Oct 10, 2009
Nc4010
It may not be possible to do this; it depends on your specific model (hardware) and the nature of the BIOS.
If you are able to do this, it will be done by changing some settings in the BIOS. Your BIOS may not allow you change any of the necessary settings. You need to be aware of the consequences of changing the fsb speed on the other components in your system, including your motherboard (see for example http://www.geekstogo.com/forum/topic/11177-how-to-overclock/ - it's rather old though). You might also do it through special software (eg SetFSB - download [not free] http://www.majorgeeks.com/files/details/setfsb.html I should warn you the it says "If you are a beginner, do not use this software. This software is for power users only. Use "SetFSB.exe" at your own risk.".
I do not advise increasing your fsb.
22.April.2014
Apr 19, 2014 | Computers & Internet
System reguirements to inrease ram memory
Ram Memory typically operates at half of the frequency rate, ('Speed'), that the Processor's -> FSB does.
Your motherboard supports Processors that have either a 400MegaHertz Front Side Bus, (400MHz FSB), or 533MHz FSB, or 800MHz FSB.
(Northwood Core for 400MHz FSB. The rest is in the other solution I provided)
Processor has a 400MHz FSB?
You can use DDR Sdram ram memory that is 266MHz.
(PC2100)
Processor has a 533MHz FSB?
You can use DDR Sdram ram memory that is either 266MHz, Or 333MHz.
(PC2100 and PC2700 respectively)
Processor has an 800MHz FSB?
You can use DDR Sdram that is either 266MHz, or 333Mhz, or 400Mhz.
(PC2100, PC2700, and PC3200, respectively)
NOTE*
When using a processor that has an 800MHz FSB, and using PC2700, (DDR at 333MHz), the PC2700 ram memory will run at ->
320MHz.
JEDEC has set the voltage requirements for DDR Sdram at 2.5 Volts.
'Performance' ram memory that is DDR Sdram may use higher voltages.
Not recommended unless you know how to overclock.
Although the motherboard, and the ram memory module may have SPD, it doesn't always work,
http://en.wikipedia.org/wiki/Serial_presence_detect
A lot of times you are faced with going into BIOS Setup, and changing the ram memory voltage, IF BIOS Setup has this feature.
This is why I say overclocking experience helps tremendously.
You want Low Density, Unbuffered, Non-ECC, and a CL of 2.5 for PC2700, and a CL of 3.0, (3) for PC3200.
[Why would anyone want to run PC2100> Lol! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 11, 2012 | Computers & Internet
I cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
Can I boot form a usb stick?
Yes, you need to go into your BIOS during startup and select boot options, select "boot from USB device" and be sure that you have the device plugged into your computer before you boot it up.
I hope this helps!
Aug 19, 2011 | MSI P45 Neo-F (MS-7519-010) Motherboard
Overclocking aopenax4b-533 mobo
In some motherboards, you can increase the multiplier, which will increase your processor speed.(Briefly, Processor Speed = FSB x Multiplier) You can also increase the chipset, memory, and CPU voltage, which will sometimes allow you to have a higher FSB. There are other settings such as PCI Bus and AGP Bus, you generally don't want to touch those, either they might put risk to your PC, or that they won't make much difference in performance. Be careful when you overclock because you can really damage your computer that way.
Mar 08, 2010 | AOpen Computers & Internet
HOW CAN I OVER CLOCK MY E7500 PROCESSOR??
Its so easy a child could do it, here is a link with step by step video guide as to how to over clock a computer, any problems get back to me as I am a expert with comps.
And please dont forget to rate me as this will help me to help others.
Here is the link.
http://www.wikihow.com/Overclock-a-PC
Cheers man
Feb 13, 2010 | Computers & Internet
2.4GHz 533MHz FSB to 2.4Ghz 800MHz FSB
Yes, you can put any Pentium 4 or Celeronsocket 478 processor in there, including those with an 800MHz FSB onthe processor. Don't waste your time with only a faster FSB unless youjust happen to have one laying around, the performance won't improvethat much. This one is $50 from Newegg.
Upgrading the components is not overclocking. Overclocking is when youforce the components to run faster than they are rated for. Yourmotherboard is set up to allow this, through the BIOS. Severaloverclocking features areintegrated into the BIOS, including the ability to adjust the FSBfrequency, and the Vcore, DDR, and AGP voltages.
If you choose to overclock, be prepared to make frequent changes toachieve best performance vs. stability. I would suggest upgrading yourcooling to the best you can afford as well. Your PC may lock up orrefuse to boot for no apparent reason if you overclock. Be preparedfor that and know what to do about it before you start youroverclocking career.
Mar 17, 2009 | ASUS Computers & Internet
Overclocking Pentium 3 667 MHz on MSI MS-6198 Motherboard
some pentiums are locked at the set speed but there are no jumpers you have to alter the settings are in the bios eg the timing and there may be step ups to increase the processor speed, but remember you get far faster response times by fitting more memory as overclocking can cause overheating and crashes.
Aug 31, 2008 | MSI MS-6198 Motherboard
848P neo ls
Hi hartterc, there is a bios update for the onboard integrated LAN card. The update, Set "Onboard LAN Boot ROM" to Enabled in BIOS. Bios Version 6.2 Date; 9-02-2006 File size 380KB.
Please allow MSI to run the (Live Update) program on you're system. If you allow this to run you will not need to download & flash you're bios.
That is what MSI states! Click on the link below for Live Updt.
http://global.msi.com.tw/index.php?func=downloadindex
You're mother board 848P Neo-V main web site.
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=582
Good Luck!
If you need help with something else, please post you're question here.
Mike
May 20, 2008 | MSI 848P Neo-V Motherboard
Strangest Overclock Failure Problem Ever
Understand that not all computers can be overclocked. For one, laptops are pretty much out of the question. Also, any OEM (original equipment manufacturer) computer, such as a Dell, HP or E-machine, will be virtually impossible to overclock, so your best bet for overclocking is to purchase or build a custom system, but keep in mind that some motherboards can't be used to overclock. Now let's begin.
The BIOS. Overclocking is best done in the computer’s BIOS. There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier CPU Clock Ratio
Nov 18, 2007 | Gigabyte GA-965P-DS3 (0818313003027)...
MSI P31 Neo-F Core 2 Quad Socket 775 1333MHz PC2-6400 ATX Motherboard Retail Logo
535 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
