Question about LG Heating & Cooling
Turns off and power light flashes
After we turn it on it only runs for a couple of minutes and then goes off and the power light flashes. Have tried on both heating and cooling with same result. Haven't needed unit much this year as weather mild so it hasn't been on for a few months.
Cleaned filters, changed batteries in remote, prayed a bit, and it worked - no idea which activity was the remedy!
Posted on Oct 04, 2009
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
Just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
Jan 16, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Fan @ compressor wont run,one light is flashing
flashing light is showing an error code. if the unit is under 5 years old it will be covered under warranty.. if you want you can try and reset the power by turning it off at the isolator next to your outdoor unit, leave it a couple of minutes and switch it back on. this will reset the fault code, if the flashing light comes back there is a definite problem, if it runs the fault may have been caused by a power surge or something
Dec 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Allan Dishwasher won't start. Clean light keeps flashing. I have tried cancelling a couple of times, and it goes through a 2 minute process and goes right back to the flashing clean light and not allowing...
Turn off the power at the breaker to the DW and wait 15 seconds and then turn it back on and see if problem is fixed. Reboots the controller.
Aug 20, 2009 | Dishwashers
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Door locked, start pause light flashing
I also have the same problem. I have got it to work by unplugging for a day and night. When I plug it in the next day it works like new for a couple days and then back to the same old "door locked" problem when the door isn't locked........BIG HEADACHE!!!!
Jun 11, 2008 | GE WSXH208A Front Load Washer
Flashing Power Light
This set is going into shutdown. It has a safety feature that will not allow the set to turn on until it checks certain circuits. Inside the set there are multiple Red LEDs and one green one, that light up at turn on. One of them is not turning on and thats the circuit that needs repaired. The most common I've found is the Horizontal Output circuit. Usually the fusible link on the secondary in the power supply. Sometimes it goes as far as the High Voltage Transformer. Of course this is just one of the possible four circuits that cause this symptom. Hope this helps.
Apr 08, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Heating & Cooling Logo
406 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
