Question about Kodak I260 Captiva IA-Express Path-Through Scanner
ERROR MESSAGE - COMMAND FAILED CHECK LOG (-4761)
I turned off the scanner at the mains and it reset itself.
Thank you anyway
Posted on Oct 02, 2009
The scutum50 NDIS protocol driver service failed to start due to the following error: The system cannot find the file specified.
1. add /BOOTLOG flag to your C:\boot.ini to get a startup log in %SystemRoot%\NTBTlog.txt 2. check %SystemRoot%\NTBTlog.txt for driver errors 3. run from a command prompt sc queryex type= all state= all bufsize= 30000 > services.log 4. check services.log for the scutum service 5. evtl. unregister the scutum service with sc del Scutum50
Mar 08, 2013 | Computers & Internet
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
On startup, my power book pro 17" will not open
Hold down Cmd-S as you start it up. You'll get 'single user mode', which is text only. See if there are any obviously bad error messages.
At some point you will hopefully get to a command prompt. You'll see a message telling you which commands to type to mount the filesystem and check for errors - follow that.
You could also type the following to look at the last 50 lines of the log file - perhaps there's a clue to the error in there: tail -50 /var/log/system.log
Restart with shutdown -r now
This may not fix your problem but it might tell you where the problem lies.
Otherwise you can boot from your installation disc and restore from that. You'll then need to get all your documents etc. from your backup.
Jan 12, 2011 | Apple MacBook Pro Notebook
There is an error in connect...........
If the error in connecting to the internet or to a LAN is prevalent with all network adapters, reset the TCP/IP Protocol stack byrunning the following command from the command prompt window:
1. Go to start menu and click on run.
2.Type in cmd.exe and press enter.
3.In the command prompt window,type in the command:
netsh int ip reset C:\connlogreset.log
The command will reset the TCP/IP protocol stack to it's defaults, and the reset data will be logged in the text document connlogreset.log.
If the above fails, disable any protocols that are not needed in the connection, e.g. SLIP(Serial Line Internet Protocol for Linux) as it's only used to connect to Linux servers in a LAN.
If using a broadband modem, disable NDIS driver wrapper from the GSM broadband client software provided with the modem, and update the software if possible.
Jan 01, 2011 | Computers & Internet
[CS Raw] Sending port check command... [FAILED] cant log in to yahoo messenger
Unable to sign in to Yahoo---problem? {CSRAW} Sending port check command. Please need help. thank you
Aug 20, 2010 | Yahoo Messenger
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
C:\Program Files (x86)\TOSHIBA\TOSHIBA Web Camera Application\TWebCamera.exe The application has failed to start because its side-by-side configuration is in correct. Please see the event log or use...
Hello, I have Toshiba Satellite L675 Model lap top. My web camera failed to initialize the application. The error message said check your camera device and restart your computer or application again. But it is not still functional. My question is Is the model built web camera? how can I check the device? how Can I solve the problem to be my web camera functional? Thank you for help
Aug 02, 2010 | Computers & Internet
Error 5
hi
check the permission of the share and also you may have to create a user just for sharing
This is a permission issue. If the net view command fails with a "System error 5 has occurred. Access is denied." message, 1) make sure you are logged on using an account that has permission to view the shares on the remote computer.
2) Need to cache credential: logon the same username and password on both computers or use net net use \\computername /user:username command.
3) Make sure the Netlogon service is running
the second question : it is a spyware
check this link in regards to clean t
Feb 13, 2008 | Microsoft Windows 2000 Professional for PC
Kodak I260 Captiva IA-Express Path-Through Scanner Logo
512 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
