Question about Tissot T Classic PR50 Quartz Watch T34.1.481.42
I need a new clasp or maybe a new bracelet so how much will this cost.
    Sniper:
  • 59 Answers
My suggestion is to take your watch to any expert watchmaker let him decide either it need clasp or new band. i hope you can get free estimate to fix this issue as well
if you are in chicago we do free estimate
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Oct 01, 2009
I accidentally stepped on my Tag Heuer TWWK1120.BB0314 bracelet now the clasp doesn't click and lock. Do I need to replace the whole bracelet or just the clasp.
Has it broken, or just been bent out of shape??? If it is just bent you could possibly take it to a TAG repairer or a watch maker to get it adjusted
Mar 25, 2011 | Tag Heuer WK1120.BB0314 Wristwatch
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
    Making the Band Shorter
  1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
  2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
  3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
  4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
  5. Making the Band Longer
  6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
  7. Step 2 Push the pin out so the link is detached from the clasp.
  8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
  9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
  10. Step 5 Repeat this process if you need to attach more than one link.
Aug 14, 2010 | Citizen Watches
Brasalet unlocks all the time by inself ,I need new brasalet or lock replaced, how I get the parts.
mcdevito75 here, Many times the Bracelet clasp can be adjusted. Look for a small watch repair shop in your area. approx, fix price, $10.00--$20.00 chaeper than new, if bracelet can be adjusted.
Jul 18, 2010 | Wittnauer 12E08 Wrist Watch
The folding deployment clasp on the bracelet/strap for my Tag 1000 series ladies watch has broken. Might a replacement clasp from any of the current tag models fit?
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Oct 17, 2009 | Watches
I can not open rolex bracelet
Sometimes Rolex bracelet clasps are very tight and this only shows the quality of the watch.
Don't be afraid to pull the clasp hard enough to open it- nothing will brake as Rolex is designed for quite hard use.
If you can't do it by hand, try to use flat butter knife end as a lever.
Dec 12, 2008 | Watches
Watch band missing link
Hi lovingdesert ,the only thing you do is go to a service center for watch,if they have clasp like of your Anne Klein,maybe they have an extra. sometimes customer leave thier adjusted clasp. or go to Anne Klein site,and order an extra clasp.
Jun 17, 2008 | Watches
Broken clasp on watch band
The only thing you do is go to service center,maybe they have an extra clasp.Somtimes customer adjusted the size of thier bracelet and when ok they leave their udjusted clasp.That's why some service center had an extra clasp.
Adjusting clasp on a Timex watch
Check that clasp from both sides and you should see spring lug ends. Use small pin to get them out(by pushing in). When pin is out you can adjust bracelet.
Good luck
Arthur
Dec 25, 2007 | Tag Heuer 2000 CN1110.BA0337 Wristwatch
Taking links out of a tag watch
TAG Link watches has very distinctive bracelets, but there is the price to pay for it- as they do wear out it's almost impossible to repair and costly replacement is needed.
In your case: open the clasp first and check if the bracelet end links has holes on sides. If yes, then find which end of the pin is split or have groove in it. This end Must come out first! Use small hammer and hardened steel pin to drive bracelet pins out.
When assembling bracelet back together, note that the pins MUST go back exactly the same way as they came out (blunt end first in and split end last).
Good luck
Arthur
Tissot T Classic PR50 Quartz Watch T34.1.481.42 Logo
154 people viewed this question
Top Tissot Watches Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Tissot Watch Expert? Answer questions, earn points and help others
