Question about Indesit WA 115 Front Load Washer
Our washing machine is stuck on the spin cycle. We let it finish, but when we try starting a new program it gets back to spin. The spin led is lit all the time. When we turn the on/off switch to stop, it just continues. I'm not sure which model it is, but it is a front loader and not too old.
  • rani_anjum Oct 01, 2009
    I might have a different model. The machine doesn't respond to when I put the on/off switch to off. I can let it finish the spin, then it will stop. Lights will flash, but once I have reset a program or even if not, it will start to blink on the spin cycle again.
    I don't understand the DOT or >dot part of the solution. Sorry to be so slow.
    Genius:
  • Indesit Master
  • 1,467 Answers
It has a reset prog..Put to stop select DOT on dial put on let it flash several times then reselect prog..Good luck
Posted on Oct 01, 2009
  • Gerry Harvey
    Gerry Harvey Oct 01, 2009
    Indesit have a reset on them....Select >dot to reset
  • Gerry Harvey
    Im assuming its an Indesit and your not slow at all, its ok for me I have done this over 30years!! If you have a handbook check this as it may help...hope you get to the bottom of the problem...
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
My F&P GW601 stops during final rinse, and beeps an error condition.
  • I just fixed a F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.)
    Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!!
Aug 29, 2015 | Fisher and Paykel Washing Machines
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
Apr 18, 2013 | Hotpoint Ultima WF860 Front Load Washer
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Doesnt go through programs
sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
Jun 10, 2009 | Washing Machines
Indesit wia111 stuck on spin cycle
OK - Try this:-
1. Position the dial on number 0 (off) and then unplug from the wall.
2. After at least 24 hours plug back in - hopefully the thing should have reset.
3. This is really important. Select a wool wash program (No 9) and allow it to complete the entire wash until the door lock light starts flashing to say it's finished.
4. Turn the dial back round to position 0 and all LEDs should go out.
That's it - The control board is reset and all should be well
In order to prevent re-occurance, try to avoid canceling programs mid-cycle. It's also a good idea to switch the dial to number 0 and switch the machine off at the wall when not in use if at all possible.
Please let me know if this works for you :)
Jul 30, 2008 | Washing Machines
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Starts cycle and then stops
Jirina, first check to make sure that both the hot and cold water valves are turned on. If that's ok, check to make sure the lid switch is being actuated. Check those first...Catriver.
May 29, 2007 | Whirlpool LTE5243D Top Load Stacked...
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
437 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
