Question about Toshiba MK1637GSX 160 GB IDE Hard Drive
Accidental reversed polarity with an external hard drive
Accidental dc reversed polarity with a 30gb toshiba mk 3025GAS external hard drive. can it be solved? Or if not can the data be recovered?
    Guru:
  • 597 Answers
You can send it so some of the data recovery people and they can usually get the data off. It's rather expensive but in your case it should be do-able.
http://support.wdc.com/recovery/index.asp?lang=en&selregion=americas
this link has several data recovery services that are all pretty good.
Posted on Oct 01, 2009
    Scholar:
  • 89 Answers
If the board is fried, you can take the platters (discs) out and put in another HD of same make and model to recover data. Will require special tools and patience. Its the only way I know to recover data from a blown HD. PS, use vinyl gloves as to not leave finger prints. and do this in the cleanest area you can find! Im not sure how you managed to reverse the polarity... hope this helps...
Testimonial: "Thank you for that."
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Need to know dc voltage for simpletech external hard drive 1tb
12 volts Dc and 1.5 ampere with External terminal as Negative Polarity and internal as Positive Polarity.
Good luck
Thanks for using FixYa.
Jul 06, 2010 | SimpleTech 1TB External USB 2.0 Hard Drive...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Toshiba MK6034GAX Shows only 30gb
Linux may be on another partition and Windows cannot recognize it, otherwise the MBR could be damaged and you should conect it externally and run a disk check on the drive.
Jul 18, 2009 | Toshiba (MK6034GAX) 60 GB Hard Drive
Sir/Madam when i attached my external 30gb hdd via usb ide data cable with my laptop message appear "unrecognized device" how i solve this problem?
You need the driver for the device. If the HDD came with a disk you will need to install that beore hand. =) Hope this works.
Ed
Jan 31, 2009 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Nov 06, 2008 | Maxtor Hard Drive
Toshiba MK1637GSX 160 GB IDE Hard Drive Logo
424 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
