Question about Dell Vostro 1500 Notebook
Suggest a lcd replacement for dell vostro 1500
I have dell vostro 1500 laptop.
recently the lcd screen got cracked in the top right corner
i want a replacement . i stay in india .
  • Dell Master
  • 32,281 Answers
You can purchase LCD screens on the Internet, I got some parts from LCD Parts - click on this link to their WEB site for parts, service and DIY info-
www.lcdparts.net
Posted on Oct 01, 2009
    Genius:
  • 1,341 Answers
The best and cheapest place to buy is on ebay as at least you have peace of mind as if there is any problem then you get your money back if you uses paypal.
Dell Vostro 1500 Repair manual and parts for backlight and inverter
You cannot replace the backlight. It is incorporated into the lcd panel and not available as a separate part. The inverter board is very easy to replace. It is located right behind the dell logo at the bottom centre of the display panel. Remove the screws on the front of the lcd bezel (under the rubber pads) and the inverter board is right there. Call 1-800-www-dell or look on ebay. Hope it's only the inverter board, as a new lcd panel is $350+. If the display is dead you can still use the laptop by connecting an external monitor to it.
Hope this helps!....let me know how you make out.
Dec 12, 2009 | Dell Vostro 1500 Notebook
There are cracks from the bottom right corner of the screen right up to the top left and when i turn it on the light still works but i cant see anything
Your laptop was dropped and the LCD backlight is what is lighting your screen. You need a replacement LCD screen.
Nov 28, 2009 | Dell Inspiron 1525 Notebook
Dell Vostro 1500 - just replaced a broken LCD screen. New screen is dim. I already checked color connections and screen brightness (FN up and down). How do I brighten my screen?
You are probably not going to like my answer but your new screen may have a bad Backlight or connection, that is what lights up the lcd panel. Check your connection at the inverter just to make sure, sometimes these connection can get reversed or get loose during the reinstall. I would take it back apart and check it from the main cable on the back all the way to the motherboard.
Oct 01, 2009 | Dell Vostro 1500 Notebook
My Dell Vostro 1500 laptop screen just blacked out. The computer is still running and when connected to an external monitor, it works. Any suggestion on what to check?
your problem is easy to fix the cable from your lcd to your motherboard is disconnected,here is what you will have to do first remove the battery,the ac cable then if you are strong enough use your fingers to pry away the hinge cover off from right to left, and then remove it from the computer.You will see below a biege cable which is the conector to your motherboard unplugged.Plug it in and carefully replace the hinge the battery turn it on and you should see the dell logo.
Good Luck
Aug 26, 2009 | Dell Vostro 1500 Notebook
Need to install a dell vostro 1500 LCD inverter
Are you good with a screwdriver? Here's a step by step procedure for replacing the LCD screen on a Dell 1500.
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-vostro-1500-laptop/
Is fairly easy, but be extremely careful of the ribbon cables, they break very easily!
Good Luck!
Jun 25, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1500 will not boot
NEEDS TO BE REINSTALLED SEE IF YOU CAN HIT F12 AND SEE IF YOU CAN GET THE BOOT MENU
Jun 06, 2009 | Dell Vostro 1500 Notebook
DELL VOSTRO Display goes blank after it is more(than halfway open
You should be able to remove the LCD hingecover and reeseat the video cable. But hte issue may be a damaged cable going thru the hinge assembly which would require a replacement LCD.http://support.dell.com/support/edocs/systems/vos1500/en/sm/display.htm#wp1179838
Jun 04, 2009 | Dell Vostro 1500 Notebook
Replacing top back cover to Lcd
In front of the screen you should see little rubber contact pieces shoild be about 4- 6 remove these and underneath are the screws to remove housing.
Inside you will see how lcd screen is attached.
Remove lcd screen then replace what you need to. This is the same for most laptops and I would just google your model # tofind out exactly how to.
May 27, 2009 | Dell Vostro 1500 Notebook
Dell Vostro 1500 Notebook Logo
273 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
