My dvd disc will not play on 2 different players. when i first received it, it played. now it doesn't. the menu comes up, but that's all. i tried to wipe it with a soft cloth, but no change.other dvd discs play, but this one does not. can you help? jiggs
If the dvd is a copy then some dvd players will not play them i have had the same problem wiv a normal dvd and found out it was the dvd because it had lots of dust in it. or you could go and buy actual cd cleaner its a spray.
Posted on Oct 01, 2009
My surround sound won't work now when I play the dvd player
Could be many things - I know, bad answer. There is no simple answer or fix.
Without more info one can only speculate.
Please determine and answer as many or all of the following so that we can help.
1) What is the make and model number of the Surround sound unit?
2) What is the make and model of the DVD player?
3) How is the DVD player connected to the Surround sound unit?
3a) Is it connected via an HDMI cable?
3b) Does the DVD player have regular stereo connections that you are using (we call these analog audio connectors)?
3c) does the DVD player have digital audio outputs that are connected to the Surround sound receiver?
4) Did the DVD player EVER make sound?
4a) if yes - what changed?
4b) if yes - does this happen with different discs?
Now some general points.
I'll assume that the other sources do work and play sound through all speakers when they are supposed to play sound through all speakers.
Then - I'll assume that without changing anything else you select the DVD player input that used to make sound but doesn't now.
Problem could be the encoding option that you have selected when you play the disc.
Many DVD's and Bluray's have audio options that you can select from the disc's main menu.
Dolby digital is the most common - also known as AC3.
Some discs have another digital audio track called DTS.
Not all surround receivers can decode all formats.
Even if your surround receiver claims to be able to decode AC3 and DTS, they will not if you don't connect the correct cable to the receiver and usually map the input to the correct digital audio connection that you are using OR if your DVD player is not capable of outputting all formats.
There are many different ways to connect the gear and many different ways one can configure correctly or not; all contributing to whether you get sound or not.
So in the above example - by selecting DTS, you do not get any sound - then try another audio track option. Basic stereo usually works (also know as PCM - which is audio like a CD).
OR maybe you never properly configured the audio properties of the DVD player.
Go into the DVD's menu or set up options and see what you find but make sure you know how the DVD is connected to your surround receiver!
As you can see - there is no simple answer without a lengthy Q and A exchange first.
May 26, 2014 | Yamaha Audio Players & Recorders
DVDR520H 1/ Trying to play DVD shows unlocked lock symbol - what does this mean ? 2/ Unit not accepting blank discs for use in recording from HDD or external source
are you referring to the symbol on the led screen? this is vital..and there will be more information so please hold your rating until we have more information
Oct 23, 2008 | Televison & Video
LG DVD recorder RH735T. Page 10 of the manual says to finalize a disc before you can play it on a different unit. But when I record something on a disc, the settings menu will not allow me to finalize
On my Toshiba DVD burners, you need to first open the DVD tray, and while it is open hit the regular menu, then DVD menu, select "FORMAT" from the DVD drop down menu, then "FORMAT MODE", which leads you to the 2 CRITICAL Choices :
1) Video Mode - Which has the DVD recording in "DVD Compatibility Mode" so it is "Compatible" with most other DVD Players
OR...
2) VR Mode- Which says "Editing Possibility mode" (Note you need a "+R DVD "to be able to do editing, at least on my machines.
Obviously you'll close the DVD tray to be ready to record
Finish the DVD, @ "DVD" Menu, & Finalize, or what you need with "VR"
Mar 02, 2014 | LG Televison & Video
We have a PD-800 dvd player. & it keeps saying "wrong disc". help
unplug for 2 minutes, then plug back in. This works,If you haven't done this already, try a different disc, preferably one it has played successfully before. If another disc works, then take a look at the working side of the disc that doesn't work and check for scratches or smudges. Or, if it's a recordable disc, it may just be a brand that your player can't handle. Every now and then, I even get a factory DVD that my player can't handle.
If this is happening with any disc, even ones it has played successfully, then we'll hope for dust on the laser lens. Get a lens cleaning disc and try it. If that doesn't work, you may have to replace the player.
Sep 15, 2011 | Protron Televison & Video
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
Cyberhome dvr1600 problems
Try cleannng machine with dvd cleanner if u have staples surplus near u it only costs 10 can cn twice thiswoked for me had a same promblem.
Aug 10, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
