I have a widescreen monitor at home, my parner
I have a widescreen monitor at home, my partner pushed a button & has gone to a standard screen size, how can i fix?
    Scholar:
  • 89 Answers
Find the menu button on the monitor, and make corrections as you need to. This will all show up on screen as you make the adjustments.
Posted on Oct 01, 2009
My Gateway monitor scrolls through settings on right side of screen
Button may be stuck pushed in, use q-tip/alcohol to clean around the button.
Dec 23, 2012 | Gateway 24" Widescreen Flat Panel TFT LCD...
Screen flashed and stopped displaying widescreen
Usually this is because the display has been changed from 16:9 (widescreen) mode to 4:3 (standard) mode. On the front panel there's a button labelled "4:3 in Wide." Press this button to return to Widescreen mode. If it says "OSD Locked" then you need to hold the "Menu" key for several seconds to unlock the controls, before changing it to widescreen.
If that doesn't correct the problem then you need to adjust your computer's output resolution to a 16:9 ratio like 1920x1080 (1080p) or 1280x720 (720p.)
Oct 22, 2012 | LG W1934S-BN 19" Monitor
My old Toshiba tv is stuck on widescreen, help..
this a problem with microprocessor signal, this will be difficult for to fix it yourself.
Every signal coming from tv goes to the CPU, you must have high skill for to repair and diagram. I can recommend you to get assistance from some repair shop TV for fix it. see the diagram and you will see the problem difficult.
God bless you
Jul 14, 2012 | Toshiba CF32F50 TV
Screen is black when computer is turned on. Tthe monitor power button blinks, but when you push the button, the light does not stop blinking and the screen stays black.. The monitor was working and last...
Try a different video card or disconnect the one you have in your PC and use the VGA monitor connection on the motherboard. If it works your video card is gone.
Dec 22, 2017 | Envision 19" Widescreen Flat Panel LCD...
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
I pushed the button next to the power button now i have no screen, i pu7shed the button again but to no avail, please help
Common failure is the caps in the inverter/power board, look for caps with bulging tops, see example of failed VIEWSONIC monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA1912wb Monitor
The screen has gone dark on my Partner PT5500, where can I
backlight is not available seprately, try to adjust the brightness and contrast and do the reset on monitor,
Feb 09, 2010 | Partner Tech PT-5500 PC Desktop
Green screen on monitor
Sony carry spares for 15 years. The question is, do you want to keep it, or buy a nice new LCD widescreen one .
Jan 14, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Computers & Internet Logo
David Payne
David Payne
