Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
How to connect back to the http://192.168.0.50
After i reset the AP i still cant connect back to the http://192.168.0.50...any idea for that?
  • 7,993 Answers
It seems to me that the default IP address for the web interface is 192.168.1.1 or 192.168.0.1 .
Hope it helps.
Posted on Oct 01, 2009
Why i cannot factory reset username, password and ssid ap? and i just can factory reset ip ap
What are you connecting the wap-1001 to? An existing network . Does the subnet mask match it defaults to 255.255.0.0
if the p.c you plug directly into the ethernet connection of the ap has a different subnet mask it can't talk to the router. how does your p.c get its ip address is it static or dynamic via dhcp server . ip is default of 192.168.1.20 also is anything assigned 192.168.1.20 .
http://download.level1.com/level1/manual/WAP-1001v1.02_UM.pdf
the default password and user name is in the user manual
Jun 17, 2015 | Levelone Level One FreeCon 802.11G Outdoor...
Cant open the admin console on mt dwl-3200ap
Try this. Push and hold in the rest button while at the same time pull out the powers supply line from the unit. Release the reset and wait 30 seconds. Push in and hold in the reset button, apply power to the unit and keep holding the rest button in for 30 seconds, then let the reset go. It should reset everything back to factory settings and hopefully let you in with the original admin pw when you bought it.
Aug 01, 2014 | D-Link Computers & Internet
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
How to reset orinoco ap 700
See the AP700 Hardware Overview below.... while the router is on.. press and hold the reset button (hole) for about 10 sec, using a paperclip.. the simplest way to restore your default setting..39f23e8.jpg
May 12, 2010 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Cant get accesss to the configuration window
In order to get to the AP, and assuming you just plugged it in, you need to put everything in the 192.168.0.x domain. The AP defaults to 192.168.0.50, so you need to make sure that the router gives out IP addresses that does not include 0.50, or change the IP address of the AP. Likewise, the computer you are trying to log into the AP needs to start in the 192.168.0.x domain, with x being anything but the gateway address (normally 1), or 50.
My guess is you have a router built into the modem and it is giving out different addresses. You can set your network address by hand to be 192.168.0.pick a number like 5 and plug into the ethernet port of the AP (may need a crossover) to get to it.
Post back and let us know what you found.
Carl
May 15, 2009 | D-Link Air DWL 700AP (DWL-700AP) 802.11b...
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
    Here are the steps to reset the access point from D-Link's website:
    Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
    The following reset procedure will completely restore the default settings on the access point including your password.
    Step 1 Locate the reset pinhole on the back of the unit.
    Step 2 With the access point powered on, press and hold the Reset button.
    Step 3 Hold the Reset button for about 10 seconds.
    Step 4 Release the Reset button.
    Step 5 The device is now at factory defaults.
    You can find the complete manual for your wireless access point here:
    http://support.dlink.com/products/view.asp?productid=DWL-2100AP
    Mar 15, 2009 | D-Link Computers & Internet
    Cant connect to the AP menu TEW-430APB
    clear your browser cache, close, relaunch your browser and try again
    You probably cant access it because you are not authorized. If its locked on your rooftop then your ISP should configure your access and that you're not authorized.
    Jan 18, 2009 | Trendware 54Mbps 802.11g Wireless AP
    Once reset right click on the connection in the task bar ( icon with two computers) click status, click properties, scroll down and select Internet Protocol (TCP/IP), click properties, click use the following IP address:, and add the following:
    IP: 192.168.0.66
    Subnet: 255.255.255.0
    Default Gateway: 192.168.0.50
    Click OK, OK, and Close, Now Enter 192.168.0.50 in internet explorer and it will work. You can now change all the settings you wish to.
    Hope this Helps
    Admin
    CCNA, CCSP, MCSA
    Dec 28, 2007 | D-Link AirPlus Xtreme G DWL-2100AP...
    AP Mode Problems
    Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
    PHASE I
    1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
    (where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
    1. Connect the EOC-3220 to your computer with a null modem serial cable.
    2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
    3. After the HyperTerminal window appears:
    a. Give this new connection a name. Ex: EOC-3220.
    b. Select correct COM port. Ex:COM1.
    c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
    4. Wait until the "#" is displayed in the HyperTerminal window.
    5. Type "flash reset", then hit enter.
    6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
    Phase II
    1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
    2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
    3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
    4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
    5) And lastly change the default user and password of your AP.
    Good Luck
    Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
    D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
    165 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
