Question about Kodak EasyShare Z760 Digital Camera
Camera will not do anything; it won't even turn off. The flash indicator and the ring around the joystick flash all the time and the lense is fully extended. It makes no difference whether it is off or in a mode or what buttons I push.
  • desertdea Oct 01, 2009
    I did try to find some firmware, but didn't have any luck. When I plug the base into the computer's USB port, it isn't even registering that the camera is there...I thought it might update the firmware itself.
    Since I wrote the original comment, the status has changed overnight. the camera still doesn't respond to any input, but the lense retracted, the green circle is steady and the flash indicator is flashing red. HMMM! It also is plugged in and on the base showing only 1 green bar lit, so it hasn't charged all night.
    Any more ideas? They'd be very appreciated!
  • desertdea Oct 02, 2009
    Still not sure what changed the status on this, and even though removing the battery didn't work at first, it did once the camera's status had changed overnight. Taking the battery out and putting it back in reset it just fine.
    Thanks for the solution suggestion.
  • 11,896 Answers
This is common problem that requires fimware update. Kodak will repair it for $50 or you may get lucky enough to find software update download on the web.
Posted on Oct 01, 2009
  • Nate Stansfield
    Nate Stansfield Oct 02, 2009
    Not a problem. Many times removing batteries or unplugging power supplies will reset the devices if left with not power for a few hours so memory is lost and systems can reset. Some camera's also have issues with some sd cards, some work, some don't, some need to be pulled out and put back in and work fine.
Light flashes 7 times
7 Flashes indicates a joystick trip. Turn off your chair, ensure the joystick is in center position without anything touching it and turn on chair. This should clear the 7 flash code.
This problem is quite common amongst power chair users. It typically occurs when something is pressing against the joystick as you are turning the chair on.
Feb 14, 2014 | Select Jazzy Used Electric Wheelchair
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Lens keep extended in an out
Jun 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
New JVC Everio MG 130
Hi, to set the time or date, first press the MENU button (beside the DIRECT DVD button). Nudge the joystick to the left to select which settings you want to edit. Then go up until you reach the general options. Nudge the joystick right. Move the joystick up until you see "CLOCK ADJUST". Here you can set the correct time. The light is really easy to access. In the shooting mode (where you are seeing live video from the lense), nudge the joystick down. The light should come on. Nudge it down again to put it on Auto. It will turn on/off depending on the lighting. Nudge it down a third time to turn it off. Hope this helps!
Eric
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
Kodak EasyShare Z760 Digital Camera Logo
75 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
