What is the ''cover bottom'' plate for?
Samsung lcd 32 inch tv Model LE32B450. In the packaging is a black plastic plate with FRONT written it. Measures about 7'' X 2''. Have racked my brains and scoured the manual but still cannot find its purpose. Shown in manual as ''cover-bottom''. Anyone help? Thanks, Peter
  • 379 Answers
Dont know this exact model, but I own a Samsung and so does my father so this proably applies:
The cover plate is supplied for use when the TV is wall mounted using a VESA mount secured to the four holes on the back of the TV. When wall mounted, the normal stand is removed and this leaves a bit of an unsightly "hole" in the case at the bottom. The cover you mention is then secured in place of the stand to make the bottom of the TV nice and neat.
You may find there was a separate leaflet in the box the TV came in detailing this aspect, which is why it isnt mentioned in the manual.
Posted on Oct 01, 2009
Testimonial: "Great. Instant solution. Many thanks."
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
Blown up
It sounds that the LOT {Line Output Transformer] to your TV has damaged. Contact any experienced service technician to get it repaired.
Jan 05, 2013 | Samsung LE32B450 32 in. LCD TV
How to make my My SAMSUNG Le32b450 turn on?
if total dead (nothing) follow the cord inside the set (note that some models have a master on/off on the rear of the set) to the line fuse that it goes almost directly to.
Next step if able to is inspect the power board for signs of damage including burnt parts or puffy filter caps.
Then the real way is to measure voltages into the power supply and out of it--some people are not able to do this--if that is you consider having a tech or shop look at the set and get an estimate.
Dec 21, 2012 | Samsung LE32B450 32 in. LCD TV
SAMSUNG Le32b450 DOESN'T TURN ON
check or have checked the power supply in this set, if not able to do it yourself have a tech or a shop examine it.
Screen colours
The T'Con board should be suspected. Contact any experienced service technician. This symptom can also occur if the display panel is faulty. Check this link.
Sep 27, 2012 | Samsung LE32B450 32 in. LCD TV
Samsung tv crackled and popped now no power
Wow that is not good. Sounds like you should just replace the whole power supply. The model is a UK model so I would look on EBAY for parts;/
Jul 18, 2012 | Samsung LE32B450 32 in. LCD TV
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
Televison & Video Logo
862 people viewed this question
Top Televison & Video Experts
