Question about IBM TravelStar 40GN 40 GB Hard Drive
Connect external hard disk IBM travel star 80GB USB port 2
Hello...please help...when i connect external hard disk IBM travel star 80GB USB port 2 , My computer not detect..please suggets, may be computer need driver to detect this USB hard disk??
    Guru:
  • 597 Answers
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Posted on Oct 01, 2009
  • 448 Answers
Connect the hard disk to any other available USB port and check if it's being recognized.
In the Device Manager, check under the Universal serial Controller whether there is exclamation mark visible after connecting the hard disk.
If there is any exclamation mark visible then right click on the device then uninstall and restart the Computer.
Furthermore, connect the hard disk to different USB port on the Computer then restart the Computer.
If everything is alright then also the Computer is unable to detect the hard drive then install the available service pack for the Operating System .
Good luck!!!!!!!!!!!!
4 Suggested Answers
  • 14 Answers
SOURCE: ibm Travelstar usb 2.0
I assume you can't see it in Windows? When you connect it can you hear the drive spin up? If not then there is a hardware problem - motor failure, jammed platter. If you hear it clicking or clunking then it is likely to be a stuck head or actuator. If so sometimes you can give the drive a sharp **** to and fro to try and spin the platter - don't do to long though. If this doesn't work then you would need the data removed by a data retrieval company.
If the drive does spin freely you may be able to fix by doing in order:
running check disk (properties of drive then tools)
using a data recovery program of which there are a few
using commercial data retrieval company.
Hope this helps
Posted on Jul 30, 2008
ginko
  • 19396 Answers
SOURCE: External USB Hard Disk is 120GB is not dected in winxp pc.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Posted on May 04, 2009
SOURCE: I need a new a new cable (fits an unusual 5-pin socket) for an ibm travelstar external hard drive
the dearlership should know what you need. the reason the socket is so different is to let you know, the stuff in which contained in this part is very sensitive and could major problems if you are not sure what your doing
Posted on Apr 15, 2012
I have ibm deskstar 20GB. Problem is that i want to connect it as an external drive through usb connector. It detects but no partition is shown in my computer. i try all jumper setting define in manual...
In Windows 7, you can use Disk management to detect and create a partition on this drive if necessary.
Steps: 1. Connect your external drive through a USB port.
2. Click Control Panel - System and Security - Create and format hard disk partitions (under Administrative tools)
3. Your drive should appear in the table below. Select the external disk and Right Click on it. You will be presented with several options (Create partition, Format, etc.). Select whatever is applicable in your case.
4. Your external drive should now be detected by Windows 7.
Mar 23, 2011 | IBM Deskstar 40GV (DTLA-305020) 20 GB Hard...
My computer refuses to recognize the external hard drive what do i do
Hello there,
What type of OS are you running ( Windows # )
What type of motherboard
Here is what i would do to start off with,
STEP ONE - Check all connections
  1. Unplug the USB data cable from the drive and the computer.
  2. Check the ends of the USB data cable to ensure that they are not damaged.
  3. Reconnect the USB data cable to the drive and the computer. Check the connections to ensure that they are secure.
    Note: If you have a Portable Hard Drive with a 2-line USB/power cable, connect both the data line and the supplemental power line (usually marked with a lightning bolt icon) to USB ports on the computer. If the status light on the drive glows steadily, the drive is receiving power. Go to step E.
  4. If you are connecting an Iomega Desktop Hard Drive, check the power supply connections to the drive and power outlet to ensure that they are secure.
  5. Restart the computer.
  6. Double click the Computer or My Computer to see if the Iomega Hard Drive is detected.
    If the Iomega Hard Drive is detected, you can now use the drive.
    If the Iomega Hard Drive is not detected, please try another USB cable and/or power supply (if available). If the Iomega Hard Drive is still not detected, continue with the next step.
if that doesn't work go to this helpful site and follow the Steps one by one to fix this problem
https://iomega-na-en.custhelp.com/app/answers/detail/a_id/1235/session/L3RpbWUvMTI5NTk4MTQwOC9zaWQvZGMzcHNaa2s%3D
don't forget to Rate
Jan 25, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
My seagate momentus 5400.2 external hard disk can't be detected by any computer. doesnt show up in the device manager, or anything. the light is on, for some reason, sometimes it blinks red/green,...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My hard drive doesn't show up
If the external hard drive is not detected by yur computer, try first connecting the drive on a different USB port so we can test the USB port and then after that if still not yet detected try a different USB cable to test the cable and after that still not detected connect the drive on different computer so we can see if this is already a hardware problem.....
Jan 05, 2010 | Sabrent eSATA External Drive Case
I have an IBM Thinkpad model T 23 and a Simpletech external hardrive, a Signature mini. They seem not to work together, i.e. the simple tech unit shows up under My Computer, but nothing is readable. The...
usb1.1 is slower than usb2 version, but should read your hard disk,, try connecting with other usb port, some times windows errors effect in detecting,,and sometimes,, problem in usb port connection
Sep 28, 2009 | IBM ThinkPad T23 2647 Notebook
USB External Harddisk Detection Problem
some people say that its because of not enough power . try inserting the hard disk in other usb slots ( at the back ). onlu usb slots at the back of my pc detects my hard disk
Aug 06, 2009 | ASUS M2N-MX Motherboard
My ibm thinkpad r51 is not starting up just keeping giving me error message and it doesn't recognize the hard drive in boot. I have to take the battery to stop the system trying restart the window again...
It appears the hard drive is faulty.
Does the hard disk LED flash when the laptop boots up?
Go into the BIOS configuration and see it the hard drive is detected, (then Startup - Boot - and look at IDE HDD0 it should list the make and model of the hard drive).
If the hard disk is detected it still could be faulty. To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port.
If the computer sees this as an external hard drive and you can open the various folders and files then the hard drive is OK and the fault could be the disk controller on the laptop's motherboard.
If the hard disk is not detected the it is faulty and you need to replace the hard drive in the laptop and install Windows etc. to get it working again.
Jul 15, 2009 | IBM ThinkPad R51 Notebook
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
IBM TravelStar 40GN 40 GB Hard Drive Logo
963 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
