Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Lec fridge - condenser tray on the outside of the fridge at the back is not evaporating the water. The tray was full and water has been leaking all over the floor for weeks. The inside of the fridge also gets very wet.
    Problem Solver:
  • 6 Answers
Check the fan near the condenser and see if it is working. If not then that is the problem
Posted on Dec 07, 2009
Superba 10 yr old fridge is blowing condensation from the bottom back vent onto wall. how do I fix so that we can still make ice and water?
Probably not condensation but run-off water generated by the auto-defrost.
This water should drain through a tube into a tray attached to the motor where heat from the motor operation causes it to evaporate.
Sometimes the drain tube or the tray becomes detached.
If condensation is forming on the outside of your fridge it indicates the internal insulation jacket is failing and repair is impractical and replacement of the fridge is desirable.
Nov 03, 2015 | KitchenAid Refrigerators
Water appears on the floor outside the fridge. I have a side by side fridge freezer, Magic Chef
There's a tray under the refrigerator that catches the water dripping down when your auto-defrost cycle runs. Usually this water evaporates before the tray overfills. Either you don't have enough air flow around the refrigerator for the water to evaporate, or the tray may have developed a leak.
Oct 10, 2014 | Refrigerators
Having thermostat problems in my Maytag fridge/bottom freezer. Pulled the fridge out and vacuumed everything. This am the copper coil on the back outside is leaking water drop by drop. The coil is not hot/...
The copper coil on the back comes from the compressor and is what makes the fridge cold but it is filled with gas. They can condensate and drip water but this isn't usually enough to notice, or cause damage. I would actually suggest looking again to check the exact source of the water. Be aware that some water from the defrost cycle is supposed to drip into the evaporator tray at the back.
Jul 10, 2013 | Refrigerators
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
I have the same problem in my freezer. Water is freezing in the top. I opened the back panel and found a half inch hole with a white plug in it, It looks like it was there on purpose. There is a hose that...
On fridges with cool wall technology, the function of the hole is to allow water which condenses on the back of the fridge to drain into the tray at the back of the fridge (on the outside) where it evaporates. It seems like this is the arrangement that you have.
Mar 04, 2011 | Whirlpool Refrigerators
The freezer leaks water and the fridge is 43 degrees and full of condensation on the inside
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Hope this works...............
Jul 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking from the bottom of the fridge.
Your fridge has likely gone through a defrost cycle. What frost was present has been melted and drained into the tray. During this cycle, the walls of the freezer are warmed up as well to facilitate melting the ice.
The air blown from the condenser fan should be blowing across the collection tray, and will evaporate the water in a short time. If you think that there is too much water, or it has started to over flow the tray, you can try scooping the water out using a small cup, or place the corner of a large towel into the water to soak it up. In either case, turn off power to the fridge first.
Jun 11, 2010 | KitchenAid Superba Architect KSCS25INSS...
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
Water on floor and under the frigerTOR
Presuming that this is a self defrosting unit, the probability is that the condensation water from the fridge section is not being disposed of as it should. Most fridges have a little hole in the back rear of the refrigeration compartment. When the unit defrosts, the water runs down the back inside, into a little gully and through the hole. At the back of the fridge (Yep, you're gonna have to drag it out and look at the back) a pipe leads down from the hole to a little tray over the compressor pump. The compressor gets hot when it is running and the water in the tray simply evaporates from the tray because it is over a heat source. My guess would be that the pipe has moved and the water is no longer dripping into the tray, or something has dislodged the tray so water is leaking from it because it's not flat, or something fell in the tray, and took up some room, so it gets more water than it can take before it all evaporates. The water then runs across the floor and out the front of the fridge
Take a look arouns the back and see what is going on there, the solution should, I hope, be fairly clear.
Feb 15, 2009 | Whirlpool ED5SHAXM Side by Side...
Refridgerator
Unless your fridge has a water supply connected to i.e for an ice maker,t about the only place the water could be coming from the condensate waste pipe.
Inside most fridges near the evaporator (the cold part) is a drain hole so that any condensate can drain out. This flows thru a tube to the back of the fridge. Normally this tube will feed into a tray and will evaporate away naturally.
You could have a look at the back of the fridge to see if this is happening.
Pease remember to rate this solution.
Dec 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
600 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
