Question about Symbol Office Equipment & Supplies
We have installed new barcode Scanners MC9000 series from Symbol but they are not able to connect to wireless network. The authentication configured at controller is WPA-PSK but this option is not available in MC9000 series. The options present here are ? Authentication - None ? Authentication - EAP-TLS ? Authentication - PEAP ? Authentication - LEAP ? Authentication - TTLS When we try to connect using any of these authentication methods, it asks for user/pass and then gives error. If we choose Authentication -None and use encryption TKIP, it proceeds and later it gives the following Error Symbol wireless out of box magic 101 production stores 1 Symbol wireless out of box magic 101 production stores 2 Symbol wireless out of box magic 101 production stores 3 Symbol wireless out of box magic 101 production stores 4 Symbol wireless out of box magic 101 production stores 5 | | |
SOURCE: DS6607 incorrectly parsing PDF417 barcode
For anyone interested, I worked with the vendor to find a solution. After some back and forth, they replied:
"I have looked up the part number of your scanner [DS6607-SR20130] and discovered that it defaults to different defaults than the standard SR20001 scanner. Specifically, it pads the data transmission with spaces and implements a custom ADF rule".
They sent codes for disabling these defaults. Moral of the story: contact your vendor.
Posted on Nov 17, 2008
rickyostrom
  • 274 Answers
SOURCE: ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Posted on Nov 24, 2008
SOURCE: Need software to install Canon Scanner N1220U with Windows Vista.
In the majority of cases where a Vista driver is not available on the website - the Windows XP Driver/software should work - you may need to tell it to run in compatibility mode though.
Posted on Feb 20, 2009
xptareq2000
  • 1447 Answers
SOURCE: Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Posted on Aug 27, 2009
anandg27
  • 1272 Answers
SOURCE: I have a Netgear wireless router DG834G and i am
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Sep 13, 2009
Need MC9060 Clean Boot Files, please help!
Hi Gregor Rogowski,
Here is the link to the files for all of the MC9xxx series
http://www.wavelink.com/Zebra-MC9000-All-Downloads/
Aug 14, 2015 | Symbol MC9060
Mc3100 find the wifi networks but can't enable the connection
Hello
I am working on the assumption that a laptop can correctly connect to the wireless network and only the MC3100 devices cannot connect.
FedEx and UPS had a similar issue as Windows CE wireless NIC's do not natively support higher level wireless encryption settings that modern wireless routers and Access Points can be configured with. This would result in an similar issue that you have described - the device can "see" the network as it is being broadcasted. When the authentication tries to occur, the two devices cannot "agree" and the device fails to connect.
If this is possible in your wireless environment, change the encryption settings on your wireless router or Access Point down from WPA2 or higher down to WEP remove encryption all together (for testing only).
It is very likely the MC3100 will be able to connect to a non-encrypted wireless network and a WEP enabled wireless network.
Once you get the device connected, try increasing the wireless encryption levels on the wireless network and see how high you can go and still have the MC3100 connect.
Hope this helps!
Nov 09, 2013 | Zebra Symbol MC3100 Wireless Mobile...
Symbol MC9090 I formatted the Symbol MC9090 installed the drive after I do a setup on the device everything works correctly, after rebooting the symbol mc 9090 its configuration is...
this is because you are cold booting the unit. Everytime you cold boot a 9090 it re-sets all saved settings. You need to warm boot only unless you want the unit reset to default. any problems please mail technical@codeo.co.uk for support - we supply MC9090's in refurbished condition complerte with like new warranty incase you need any
Oct 21, 2011 | Zebra Symbol Technologies MC909X-G Series...
How do I connect my N410 symbol bar code scanner (running on Windows Mobile) to my wireless router?
If you have a model with Wireless functionality, can you use the Fusion application to manage your wireless connection. There should be an icon in the right corner.
You need to find out which authentication and encryption is used on the specific WLAN.
Then launch through clicking on the Fusion icon the Find WLANs dialog and follow the process of creating of new WLAN Profile.
Feb 28, 2010 | Zebra Symbol Technologies MC909X-G Series...
AP Wireless Network issue with MC9060
TRY TO UPGRADE THE AP FIRMWARE
Nov 09, 2009 | Symbol MC9060-G
Our keyboards lock and we cannot enter data or log in. Cold boots do not work. What do we do?
The keyboards on MC9000 series terminals are replacable. You could have one of two problems-- corrupt firmware or an improperly installed keyboard. Contact the Symbol/Motorola Help Desk at 1-800-653-5350
Jun 04, 2009 | Zebra Symbol Technologies MC909X-G Series...
Symbol ppt8846 aegis client 2.1.4 will not re-authenticate after Hard boot
Update the OS to the latest version available from Motorola. This version does support TKIP and you won't need to use ageis client.
May 15, 2008 | Symbol PPT 8800 Wireless Barcode Scanner
Connection Issues
can you give more info,
1>can you see the network? (scan)
2>can you connect to the network?
3>do you get a valid IP?
4>can you ping the server?
if you can not connect to the network(2) but see the network(1) via scan the problem is in your wireless profile, delete the profile and resetup, check that the region settings in the profile match that of the unit.
i will need more info about you network, ie wep/wpa? ch? authentication type? and so on
Oct 19, 2006 | Symbol MC9063-K (mc9063kkehbeea4ww)...
95 people viewed this question
Top Symbol Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
